Door stuck shut
Old April 27th, 2016, 06:31 PM
1965F85_scholten's Avatar
Door stuck shut
Hi, my 65 F85, after sitting over the winter has the passenger door stuck shut. I can see when I push either the door button, or pull on the door handle that the lock assembly rocks and appears to unlatch, the door loosens from the frame but it acts as if the assembly is still locked around the bolt. The door is not stuck to the frame. It wiggles, it just does not disengage from the door bolt. In other words, it appears to be dis-engaging as I would expect. Aside from drilling out the door latch from inside the door frame and take it apart one piece at a time I have no idea on how to get the door open to even fix it .
Help!
1965F85_scholten is offline
at3reg98
Body work
June 24th, 2012 07:07 PM
Gary's 2 442-S
February 16th, 2011 07:34 PM
Wyze
December 20th, 2009 05:57 PM
American Lead
April 20th, 2009 12:47 PM
d.smith1
January 30th, 2008 12:08 PM
Quick Reply: Door stuck shut
