64 F85 Club Coupe door panels
Guys getting closer to putting the interior in my 64 F-85 "Pro Touring" post car. Is there anybody that makes the front door panels and rear qtr.panels? These do not come all the way up like the Holiday or convertible cars. There the same as a 64-65 Lemans/GTO. So if all else fails , I can get the pre-cut front and rear cardboard of the panels from Ames Performance ( Pontiac vendor) and send them over to an upholstery shop here in the Dallas area. Thanks.
I ordered the GTO cardboard panels from Ames, and have decided to have an upholstery shop work with the Scat Pro Bucket seat pattern for about the same money as buying the Cutlass panels. They can also re-cover the back seat to match the buckets. Going to have them install carpet too because I installed the B@M Bandit shifter and they will have to work around that too. First I have to get this car running! The 67 400E that's in there has not been started in 7 years. It should be fine, has maybe 5K miles since the rebuild ( stock) and was running fine when I pulled it out of the 67.
Well I think that makes sense, they can try to match those new Scat seats and overall you will probably save quite a bit of valuable time. I don't think I have ever used Ames for anything but I will have to check them out!
