1970 dual gate center console
Old January 10th, 2016, 08:17 AM
Achcoastal's Avatar
how do i remove the center console on a 1970 dual gate cutlass? i have already removed the two forward scews. thanks alan
Achcoastal is offline
Old January 10th, 2016, 09:56 AM
delete
droptopron's Avatar
Remove the liner from the console & there is a rear bracket
droptopron is offline
Old January 10th, 2016, 10:01 AM
Remove the console liner inserts and you will be a able to see a couple screws for the rear attaching points.
The inserts are held in by 3 or 4 screws along the centerline and the plunger switch for the light at the rear.
Fun71 is offline
Old January 10th, 2016, 01:33 PM
Achcoastal's Avatar
1970 dual gate console
thanks for your help,had to repair indicator lamp wiring. repair complete, console back together,the only thing i need to complete the job is dual gate panel missing rocket insignia. (i know no biggy).cant seem to find just the insignia alone ,without having to buy whole panel at opgi and fusick. any ideas?
Old January 10th, 2016, 05:08 PM
4speed455's Avatar
http://realoldspower.prophpbb.com/po...0emblem#p93841
Apparently Fusick sells an emblem for 69 442 door panels that will work.
http://www.fusickautomotiveproducts....?number=SE69DP
It's black instead of red though.
4speed455 is offline
Old January 10th, 2016, 05:58 PM
Achcoastal's Avatar
thank you 4speed 455, i will look in to it !
Prophe'c
September 3rd, 2015 06:55 PM
Doomah
June 13th, 2012 12:44 PM
pcard
April 4th, 2012 07:36 AM
Prophe'c
September 24th, 2010 07:36 PM
Quick Reply: 1970 dual gate center console
