69 H/O intake
sounds like a deal to me since the last one i saw for sale the guy was asking 8500! (sure glad im not looking for one!! LOL)
BTW --- Just what is the difference about it ? Is the casting number different? Is that the only diff? Usually there are other differences to warrant a different casting number? I've never had one to look at to actually compare?
Thus rr's spending spree lately...
"BTW --- Just what is the difference about it ? Is the casting number different? Is that the only diff? Usually there are other differences to warrant a different casting number? I've never had one to look at to actually compare?"
Casting number is different though they used the same main ID _LETTER_ "J"
Common:
J on passenger side in depression aft of thermostat.
398662 Casting # aft of carb
Cavity for divorced choke coil
Rare '69 H/O only:
J is on LH side, not passenger side.
Casting # aft of carb is 405233
On RH side is a boss that goes from water passage to #2 intake runner, drilled thru to cankcase and fitted with a 1/2" nipple for the PCV valve rubber elbow Gr. 3.410?, PN 405144.
Same choke coil cavity
Both have two threaded ports for water temp sensors.
Here are some photos of my REPLICA rare intake showing APPROXIMATELY what the real ones look like:
http://www.ebay.com/itm/150772154268...84.m1555.l2649
Note the common cracks areas. Note that on a real one the PCV boss is tied to both nearby walls- I was afraid that the boss would crack away from one or both walls due to thermal expansion, so I tie only to the intake runner wall. Note that the replica boss must be secured mechanically to the intake, thus the nut and threaded tube underside. Real ones would just have a hole thru solid cast iron for the PCV. I also leave a marking underside on the replicas to ward off truth decay in the future.
Common:
Rare '69 H/O only:
TIM FISKUS
May 12th, 2013 05:17 AM
Wildcard
December 26th, 2012 07:48 AM
Nickyloves442s
October 24th, 2012 04:55 PM
svnt442
July 17th, 2011 04:43 PM
