Differences between Cutlass S and Supreme
Old November 25th, 2014, 08:33 PM
yamahondarider's Avatar
Hey guys, I have two 1969 Cutlass S's. Ones my project the other is a parts car. I've gotten what I need off the parts car and yet its still a running driving car, just no interior and some other misc stuff. A tree had fallen on the car ruining the body but otherwise its a functioning driveable car. I found a 1972 Cutlass Supreme body (notchback trunk car, not the fastback "S" and 442 style) and I'm wondering if these cars had a different frame or wheelbase like the Monte Carlos? Any difference in the suspension? Steering columns and stuff on the firewall (IE brakes, A/C boxes, ect)? The price is right and as long as I won't run into too many issues i may pick up the '72 Supreme shell to put on the '69 S running gear and frame.
yamahondarider is offline
Old November 25th, 2014, 09:09 PM
dnmfranco's Avatar
Same frame and that wont matter if it was different since your plan is to drop a 69 350 into the 72
steering column will work
to the best of my knowledge most if not all the suspension (brakes and ect) will be the same
parts beyond firewall will work as well
if 72 frame is okay why change - a lot of unnecessary work. Or does the shell not come w a frame.
take your 69 tranny/350 and put it in
you will need a different drive shaft other than the 69 I believe due to the 72 rear unless you are changing that as well
If no 72 frame then better talk to the 72 guys
dnmfranco is offline
Old November 25th, 2014, 09:13 PM
The 72 body does not come with a frame. I'm only buying the body hull with doors trunk lid and front sheet metal, I'd be using the engine/trans/suspension/brakes/wiring/master cyl/steering column/radiator/gas tank/everything I can from the '72. Obviously dash and interior and body stuff will be different but I just wanted to check on the main parts. Oh also, about how heavy would a body with no doors or trunk lid be? just the main body shell. No interior ect
Old November 25th, 2014, 09:36 PM
dnmfranco's Avatar
okay
shouldn't be that heavy at all w all that absent
Old November 25th, 2014, 09:40 PM
okay
Yeah I figure 3-4 people should be able to carry it onto and off of a trailer. The doors and trunk and fenders and all can go in my van.
Old November 25th, 2014, 10:00 PM
dnmfranco's Avatar
agreed, shouldn't be that bad
far as the 72 parts swap check w the 72 guys to make sure
one guy to go is Mark Prince , very knowledgeable on 72's
I forget his user name on here but search him out
Old November 25th, 2014, 10:02 PM
dnmfranco's Avatar
actually just found it is wmachines - Mark Prince
Old November 26th, 2014, 04:51 AM
Eddie Hansen's Avatar
some of the interior should work
Inwould think the seatsvwill work different pattern but should work make sure you get the registration /title to the shell,
Eddie Hansen is offline
98regency
May 15th, 2014 02:31 PM
66Dynamic
April 17th, 2014 04:52 PM
MBrown
January 24th, 2013 06:37 AM
83 delta 88
June 18th, 2010 06:05 PM
64 Cutlass
January 22nd, 2010 06:59 AM
Quick Reply: Differences between Cutlass S and Supreme
