72 convertible cutlass top motor
Old May 3rd, 2014, 07:00 PM
Redbud40's Avatar
Installed new pump motor on vehicle.. Any techniques or suggestions on inserting the three rubber grommets into the holes?? Tried a little oil, Vaseline to no avail. Got the single on but not so much on the double side. Have it attached now with some small C clamps. Good news top works Great. Thanks
Redbud40 is offline
Old May 28th, 2014, 07:53 AM
dalilama's Avatar
Hey Redbud -
Congrats on getting the top working. Get a threaded bolt with some nuts and washers that are wider that the grommets. Then thread the bolt thru the oiled grommet and the motor hole, and put a washer and a nut (in that order) on each end. Snug it up by hand and then use a wrench to slowly turn the nut on the top of the washer/grommet until the grommet pops in. Should work.
I'm about to dive into this on a 72 vert that the top won't budge on. No motor noise at all. Any tips?
dalilama is offline
Old May 28th, 2014, 02:05 PM
Redbud40's Avatar
Thanks for the tip sounds like a plan for the grommet. Rocker switch? They seem to go before the actual motor. My switch was bad and pump was old(original) so I decided to just buy a new pump. Gonna test my old pump to see if it still works it did last time I used it about two years ago. I was gonna post it here later if someone wanted to upgrade and or rebuild.
Mike
Redbud40 is offline
Old July 21st, 2014, 09:31 PM
Oldsmobomb's Avatar
Quote: "No motor noise at all. Any tips?"
Sorry to have to say this but I spent 30 minutes on a fully worded reply covering top pump motor overhauls and the posting "reply" function apparently "timed out" or something ?? It asked me to "log in" again when I was already logged in. It then ate my entire reply.
I am not going to redo that tutorial. If you want to know the procedure - contact me direct email.
Note to Administrator: This is not the first time such an annoyance has happened - if you do not want members to post considered replies (vs 2 sentence blurbs) just say so!
Oldsmobomb is offline
GoBigRed
Brakes/Hydraulic Systems
15
October 5th, 2015 01:00 PM
kaveman828
May 29th, 2012 10:44 AM
Southern_Hospitality
October 12th, 2011 06:55 PM
October 12th, 2011 08:01 AM
1969goatman
September 8th, 2010 02:08 PM
Quick Reply: 72 convertible cutlass top motor
