442 hood hinges
Old March 13th, 2017, 11:12 AM
tbdragon's Avatar
442 hood hinges
Should hood hinges be painted that flat black like inside engine compartment? or body color or both?
tbdragon is offline
Old March 13th, 2017, 11:45 AM
stevengerard's Avatar
Hood hinges grey phosphate coated — a grayish color. You can spray it with "cast" grey and then on mist from farther way to add a dusting of flat powdery final coat .
stevengerard is offline
Old March 13th, 2017, 12:52 PM
Randy C.
rcorrigan5's Avatar
I used cast grey as stevengerard stated. But I removed the springs, cleaned 'em up and painted them stainless steel. The assembled hinges look pretty close to original even though they are painted.
Randy C.
rcorrigan5 is offline
Old March 13th, 2017, 03:45 PM
tbdragon's Avatar
Thanks guys I have a old set from a parts car that are at least a matched set that I have already got rust off of and I can see grey on one and somebody must have painted other black that will not come off easy... may just replace springs as I cant do inside of springs... not sure but I have been living with one bad hinge for 2 years and don't want to have to do this again soon... I appreciate the input... I have some of the aspen green in paint can and will mist it after the cast paint... what is best lubricant for the hinges?
tbdragon is offline
Old March 13th, 2017, 03:48 PM
mrolds69's Avatar
X3...they were grey phosphate. The technique Steven mentioned is very good, I've used it myself for some parts on my GS. My hinges I use POR 15 manifold factory grey, it's very durable, and an absolutely killer look. You can do them and the springs ON the car by carefully masking, and remove one bolt at a time. You use a foam brush, you don't need to bake them. Bare in mind I did my 442 hinges about 18 YEARS ago, they have been opened hundreds of times. The car scored 999 last time out for Sr. Preservation, I've never had anybody question them. It's one of the best "tricks" I know.
mrolds69 is offline
Old March 13th, 2017, 03:51 PM
mrolds69's Avatar
You do the springs by partially closing the hood, you can paint this stuff right over the black scuffed.
mrolds69 is offline
Old March 14th, 2017, 12:51 AM
tbdragon's Avatar
I just ordered the por 15 manifold grey as I need the manifolds painted anyhow then I will give light dusting of aspen green after... thanks for the help guys!
tbdragon is offline
Old March 14th, 2017, 05:08 AM
you don't need to mist it with the aspen green. I meant you mist it with the cast grey from a distance as that adds a little texture and flatness to the finish. If you mist it with green it will look like over spray. No need for that - unless you want to.
Old March 14th, 2017, 02:14 PM
tbdragon's Avatar
sorry didn't know and couldn't remember what my olds cars hinges looked like even though I looked at them many times... thank you for the guidance guys
tbdragon is offline
Old March 19th, 2017, 03:51 PM
tbdragon's Avatar
Ok as a follow up I have finished the used hinges and they look brand new... I used phosphoric acid and scrubbed them down... rinsed the rust and old paint off... let dry for a day then used wire brush to make surface finish better... wiped down with cloth and painted with the POR-15 grey manifold paint mentioned above and they look fantastic! Going to oil and install them today... thank you all for much appreciated advise!
tbdragon is offline
Old March 19th, 2017, 06:16 PM
mrolds69's Avatar
Good deal, glad you are happy with them. I've had hinges plated before, but for a driven car that stuff has a nice durable, driveable finish.
mrolds69 is offline
Old March 19th, 2017, 08:17 PM
tbdragon's Avatar
installed and happy
lookin good
tbdragon is offline
MLK-442
May 8th, 2011 05:07 AM
bluechevelless
September 29th, 2010 05:22 PM
georgiaboy697
July 2nd, 2010 09:23 PM
Eightupman
February 1st, 2010 10:23 PM
Jolly Green
August 7th, 2007 10:40 PM
Quick Reply: 442 hood hinges
