Oil pan removal
Old February 26th, 2017, 06:33 AM
deadeyejedi's Avatar
Oil pan removal
Has any one had a good experience removing the oil pan with the motor still in the car? Was thinking about changing the pan gasket on my 76 while I'm doing some other upgrades . Should I just bite the bullet and pull the motor ?
deadeyejedi is offline
Old February 26th, 2017, 07:08 AM
Good experience...? There is no such thing trying to do it in the car. Pull the engine, its so much easier. Here are some other opinions:
https://classicoldsmobile.com/forums...n-removal.html
oldcutlass is online now
Old February 26th, 2017, 07:16 AM
There is no such thing as a good experience removing the oil pan with the motor still in the car.
I've done it. It can be done. But it ain't fun, and it's enough work that there's a strong argument for just pulling the engine instead, and then being able to work on it properly.
edit: Eric beat me to it.
MDchanic is offline
Old February 26th, 2017, 07:22 AM
This question comes up several times a year. The bottom line is that while it is possible to remove the pan with the engine in the car, you are only a few bellhousing and converter bolts away from pulling the engine. Your life will be MUCH happier if you do that. Think about it - once you get the pan off, you'll be under the car with oil dripping off the crank into your face.
joe_padavano is online now
Old February 26th, 2017, 08:31 AM
Thank you guys I value your opinions .
Kaline
April 18th, 2022 03:35 PM
Lawndog
August 21st, 2011 10:14 PM
leadfoot067
December 3rd, 2010 06:11 PM
Fletch
May 18th, 2010 12:40 PM
Quick Reply: Oil pan removal
