67 Cutlass Radiator Hoses
Old February 25th, 2017, 07:14 AM
Roger60's Avatar
Trying to replace upper and lower radiator hoses. 67 Cutlass 330 4bbl h/c with a/c 3 core radiator. From what is available, the upper is too short to the engine to go around the alternator and the lower has the wrong bend to go around the frame. Would anyone have the correct numbers for replacements? Thanks.
Roger60 is offline
Old February 25th, 2017, 07:36 AM
Rockauto lists a few different part numbers and manufacturers with pictures of the hoses. You might can use those numbers at the parts store. Another idea is if you have the old hoses that worked, take them to the store and see if they can match them up.
oldcutlass is offline
Old February 25th, 2017, 09:37 AM
Roger60's Avatar
67Radiator hoses
Thanks, I've got all that. My issue is the upper hose doesn't seem to be for engine with a/c, as the top mounted alternator is in the way, making the hose a few inches too short at the engine. The GM # matches to the Gates # and it is the only hose that comes up. Also is the # hose that Fusick sells. So, I have to think I'm doing something wrong.
Roger60 is offline
Old February 25th, 2017, 11:00 AM
Can you post a picture as to where the trouble is?
Old February 25th, 2017, 12:51 PM
Roger60's Avatar
OK, here's the deal. The radiator top port will take 2 sizes of hose. I don't know if this is original or a replacement, it looked like a fresh recore when I got it. Also, I found this adapter in the original hose and when installed on the smaller diameter of the port, it fits quite well. Look at the pics. Thanks.
Roger60 is offline
Old February 25th, 2017, 01:04 PM
I don't know if thats an original radiator or not, I don't think the original had a stepped upper hose bib. I have an adapter on my lower hose with aftermarket radiator, it works well.
This is not the issue you described in your first post.
Old February 25th, 2017, 04:15 PM
That's a one-size-fits-all generic replacement radiator. The factory ones did not have the stepped hose barb. The spacer in your hose is also an aftermarket part for similar applications. Suppliers are always trying to reduce part numbers that they have to warehouse by making one part fit multiple applications. Some vendors make all their radiators with the smaller hose barb and supply that spacer for applications that use the larger one. Other vendors make the stepped hose barb. You shouldn't need both the spacer and the stepped hose barb - one or the other.
joe_padavano is offline
Old February 25th, 2017, 08:12 PM
Roger60's Avatar
I was not aware of this issue in my first post. By moving the hose to the closer bib, it had the length to reach the engine. Progressive discussions are how these issues are solved. Thank you.
Roger60 is offline
Old February 26th, 2017, 05:49 AM
Glad its fixed. I agree about the progressive discussions, sometimes its better to think out loud and bounce ideas off others.
Oldssupreme
September 20th, 2016 07:48 AM
Christophe2m6
June 21st, 2015 03:23 PM
squirell
August 25th, 2009 09:21 AM
65cutty
June 12th, 2009 06:45 AM
Iragh
November 17th, 2008 03:41 PM
Quick Reply: 67 Cutlass Radiator Hoses
