Plugs from hell or All plugged up.
Old February 22nd, 2017, 10:38 AM
  #41
anthonyP's Avatar
The SS-1 rims look like the later 14x7 type. What is wrong with the hood, it looks to be the factory stock one, including the standard 442 pin striping?
anthonyP is offline
Old February 22nd, 2017, 05:11 PM
  #42
Out of Line, Everytime😉
olds 307 and 403's Avatar
The 10 bolt valve covers and corresponding bolts was a dead give away to 76 and older heads. The long reach plugs Joe shows are 307 swirl port only, 85-90. Use the NGK XR45 plugs. Get a 625 cfm Street Demon carb, a massively better carb than the piece of junk Edelbrock carb.
olds 307 and 403 is online now
Old February 23rd, 2017, 06:39 AM
  #43
My only point with the 307 plugs was to demonstrate that there ARE 5/8" hex, gasket seat plugs that WILL screw into the early heads and will work. The reality is that the OP had incorrect taper seat plugs in the car.
joe_padavano is offline
Old March 22nd, 2017, 12:30 PM
  #44
Kraven Moorehead's Avatar
Hey Joe,
We are planning on a disc brake conversion for the front and I saw another thread on the subject wherein you were a bit of an authority on same. My question to you is; Will the current wheels work after said conversion? Thanks in advance for your consideration.
Kraven Moorehead is offline
Old March 22nd, 2017, 12:38 PM
  #45
Originally Posted by Kraven Moorehead
Hey Joe,
I can't tell from the photos in this thread what wheels you have. The easy thing to do is to pull one of them and look at the backside. In this photo, the disk brake wheel is on the left. Note the shape of the dropped center section (yellow arrow vs. green). Also note the bead (light blue arrow). You can see this feature from the back of the wheel even with the tires mounted. All disk brake wheels have this bead.
MrGasser
September 23rd, 2015 07:42 AM
bob p
April 10th, 2015 01:55 PM
MDchanic
March 25th, 2013 05:01 AM
68conv455
November 29th, 2009 05:38 PM
relic
February 23rd, 2008 04:43 AM
Quick Reply: Plugs from hell or All plugged up.
