Oldsmobile in Action Vol. 1 anyone have a copy?
Old January 30th, 2017, 10:04 AM
FStanley's Avatar
Does anyone have a copy of Oldsmbile in Action Vol. 1?
http://thumbs.ebaystatic.com/images/...EPo/s-l225.jpg
If so, could you look for a phrase in it about cooling system info, I believe in the it says something about Olds engines with Heavy Duty cooling used a smaller diameter water pump empeller to slow the coolant flow down to get more heat heat from the engine and hence cool better.
If you find this could you:
1. Scan this part of the magazine.
or
2. at least write out the exact working of this info in a reply to this post. OR am I full of balonie..
or
3. Both
Thanks,
Fred
FStanley is offline
Old January 30th, 2017, 04:42 PM
Old(s)GuysRule
67OAI's Avatar
Scan sent to you in a pm.
67OAI is offline
70-442-W30
March 23rd, 2016 08:23 AM
Hairy Olds
April 19th, 2014 12:30 PM
Hairy Olds
April 11th, 2014 01:40 PM
69HO43
December 24th, 2011 12:02 PM
Kaline
October 21st, 2008 10:12 PM
Quick Reply: Oldsmobile in Action Vol. 1 anyone have a copy?
