Where can I find matching numbers
Old January 8th, 2017, 06:29 PM
Thirtyseven's Avatar
I have a 1970 CS.
Here are the numbers I have found. One was on the inside dash under the front window, the other was mounted inside the engine compartment.
I am wanting to know if the engine block is original. It is a 455 and I think the original car came with a 350.
Thirtyseven is offline
Old January 8th, 2017, 06:37 PM
classicmuscle442's Avatar
Block stamping is by #1 spark plug and if you have power steering it's behind the bracket. Last six digits on pad should match your dash vin.
classicmuscle442 is offline
Old January 8th, 2017, 09:12 PM
same but different
don71's Avatar
Like mentioned, power steering/bracket might get in the way but it will look a lot like this when you finally get there and find it. Its a small area and not as easy to read as this pic might lend it to be.
don71 is offline
Old January 9th, 2017, 04:20 AM
Sammy70 455 Supreme
sammy's Avatar
Great looking car!.
sammy is offline
Old January 9th, 2017, 05:58 AM
Specifically, the number should be 30G148693.
MDchanic is offline
Old January 9th, 2017, 06:47 AM
Both the block and the trans will have VIN derivative stamps that should match the VIN if they are original. A factory 455 car would have come only with a TH400, not a TH350. Check to see if the trans crossmember has ever been bolted in the forward (TH350) position. There will usually be telltale scrape marks around those bolt holes in the frame if it has. Here are the locations of the VIN derivatives.
joe_padavano is offline
SeanMiller063
September 9th, 2014 01:04 AM
Johnd
November 28th, 2013 08:31 AM
Al2011
August 10th, 2011 08:58 AM
mscofer
April 4th, 2010 06:35 PM
shaks 442 clone
February 19th, 2008 04:51 PM
Quick Reply: Where can I find matching numbers
