| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| General Questions Place to post your questions that don't fit into one of the specific forums below. |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
Hi guys.
Just read a thread about using an early, non dual range hydro, on a later, 394 eng. The writer made it seem complicated. When did these engine go to external balancing from internal?? When was the last year the 371,394 used the hydro, before going to the slim jim?? Will the early non dual range trans hook up to the later dual range bellhousing and converter/coupling to avoid an unbalance condition?? This is about putting a 394, or maybe a 371, in a 49/50 Olds using the original trans. Appreciate any input. TKS DAN |
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
Hot Rodder at heart Administrator
Dan,
Sorry, I can't answer you question but I wanted to welcome you to our site. I am sure you will be getting some good info soon.
__________________
Dan '77 Cutlass Supreme '46 2 door "The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB. |
#3 (permalink) | |||
Junior Member
Hydra-Matic (N-Dr-Lo-R) was used from '39 to '51, Dual range Hydra-Matic (N-Dr-S-Lo-R) from '52 to '56, and Jetaway Hydra-Matic (A different trans) from '56 to '60.
Quote:
Quote:
Quote:
Use your '50 flywheel. Have a competent shop transfer balance it to the 371/394 unit. You may need to use a pilot bushing with the later crank. Norm |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 50-56 manual trans | woodie | Eighty-Eight | 1 | January 4th, 2009 06:46 PM |
| trans help please! | ChrisM | Transmission | 3 | December 12th, 2008 01:31 PM |
| What Trans. | WEBBISH | Transmission | 7 | November 25th, 2008 01:30 PM |
| trans compatibility question... | delta881972 | Big Blocks | 15 | August 25th, 2008 03:12 PM |
| 79 trans am | bigshot846 | Cars For Sale | 0 | November 22nd, 2006 09:09 PM |
