72 cutlass supreme springs
Old February 7th, 2016, 08:22 PM
deadeyejedi's Avatar
not sure whats going on with the new front coil springs i installed ,but ive got everything on the car except the hood and still cant get the shocks installed seems way too stiff .i ordered 350 springs w/ac from rock auto .i did eliminate the ac but wanted a little stiffer spring.the new springs are physically the same height as the originals.ive double checked that they are seated properly .i have new tubular a-arms not sure if that changes things .i fear i will have to change them out was hoping for some insight thanks
deadeyejedi is offline
Old February 7th, 2016, 08:24 PM
this is how high it sits if it helps
Old February 7th, 2016, 08:27 PM
sorry that was the wrong pic
Old February 8th, 2016, 05:40 AM
When you put the front shocks in the pocket with the upper shank through the mounting hole, how much shock is still hanging down before you push it up to install the lower fasteners?
oldcutlass is online now
Old February 8th, 2016, 07:19 AM
Old February 8th, 2016, 07:27 AM
I'll have to get back to you when I get home I'll take some measurements .right now I have 8.5 inches between the top of the inner fender and top of the tire not sure what that measurement would be on stock ride height but seems excessive to me .before I installed the fenders and core support there wasn't enough of the shock shaft sticking up to get the nut started
Old February 8th, 2016, 07:33 AM
NHolds's Avatar
It's most likely because of the tubular arms. I don't think the spring pockets are as deep as originals. I put tubular on mine, but went with adjustable coil overs.
NHolds is offline
Old February 8th, 2016, 08:15 AM
Did you tighten the control arms without weight on them?
Old February 8th, 2016, 08:24 AM
I did the final tightening after it was on the ground but there was no front end or engine in the car
Old February 8th, 2016, 09:26 AM
NHolds's Avatar
I think you just answered your question.
NHolds is offline
That may be the problem. Try loosening, bounce the car, and retighten.
Old February 8th, 2016, 12:26 PM
That may very well be it I'll try it when I get home
Old February 10th, 2016, 04:43 AM
finally got back to the olds mother nature threw a wrench in the works with snow i had to deal with .i loosened the a arm bolts and it seemed to do the trick ,the car is now bouncing on the springs pretty good ,i will double check the torque specs and try to install the shocks .thanks for the help i should have left the bolts loose until after the motor went in .it always helps to talk it out with other members
Old February 10th, 2016, 03:05 PM
i did get the shocks bolted in and to answer your question eric after getting the top shank nut of the shock just started with the control arms loose and car on its wheels after bouncing it i had about 1 1/4 inches hanging down does that sound about right ?
Old February 10th, 2016, 03:25 PM
Everything may need to settle a bit. I'd leave it alone until you can drive it and exercise the suspension.
Alex72cutty
Suspension & Handling
22
April 15th, 2015 10:59 PM
bigjaythe1st
May 8th, 2012 05:45 PM
1acesmith
August 11th, 2011 11:03 AM
olds70supreme
August 1st, 2011 05:22 PM
oldsconv
August 3rd, 2008 12:03 PM
Quick Reply: 72 cutlass supreme springs
