Cam
Old May 27th, 2015, 02:38 PM
Richard2010's Avatar
Cam
Hay guys im looking for some help. I have a 71 olds Cutlas supreme rocket 350, with 80,000 original miles. I'm looking for a nice aggressive sounding cam which can provide the best power without having to change out the springs ? Any suggestions how aggressive I can go before having. To change out the springs ? Car has a edlebrock performer intake, summit 660 carb, and some long tube headers shift kit and getting 3;73 gears. Appreciate the help all ?
Richard2010 is offline
Old May 27th, 2015, 02:45 PM
Beer Connoisseur
70cutty's Avatar
Best thing to do is PM Mark - Cutlassefi here on CO, if he doesn't chime in soon. He can set you up. Great guy to deal with and a cam guru.
70cutty is offline
Old May 27th, 2015, 06:24 PM
Rocket Renegade!
Is the engine internally all original? More to the point, does it retain the factory 8.2-1 compression? If so, this will definitely limit how big a cam you can run.
BangScreech4-4-2 is online now
Old May 27th, 2015, 08:01 PM
Not sure. I was looking at the 270 H from comp cams. I was told I could use this ?
Old May 27th, 2015, 08:29 PM
Rocket Renegade!
That's a lot of camshaft, especially if you have the low compression. With an 8.2 ratio, I'd keep it under 215 degrees duration @ 0.050 and under 0.460 lift. You REALLY need to know your compression ratio before you select a performance cam.
A lot of people on this site tend to frown upon Comp Cams, too. I have one in my car (see avatar) and have been very happy with it, but there seems to be the perception that they're designed for Chevys with Olds applications as an afterthought.
Last edited by BangScreech4-4-2; May 27th, 2015 at 08:32 PM. Reason: Weird shit happening with the margins.
Old May 27th, 2015, 10:10 PM
Yeah after doin the research im going to stay away from a cam, I have a new LS3 that I built(carb swap) cams, with 4l60 tranny been waiting to drop it in sounds like now may be the time !!!
Old May 27th, 2015, 11:47 PM
Rocket Renegade!
... okay ...
Old May 28th, 2015, 08:33 AM
... okay ...
Thank you all for your input and help 👌👌
Old May 28th, 2015, 09:52 AM
Rocket Renegade!
No worries!
grmchne78
June 25th, 2015 06:23 PM
Oldsmaniac
June 20th, 2014 05:44 AM
Uncle Hulka
March 12th, 2014 03:41 PM
72RocketPower
August 11th, 2005 04:51 AM
Rocketman
November 22nd, 2004 01:59 PM
Quick Reply: Cam
