Early Cutlass places
Looking at a 63 Cutlass tomorrow morning. No doubt I'll bring home another project. 2 on jack stands in the shop now.
I don't see much on the older models. I am familiar enough to know they share more with the Corvair than newer A-bodies.
Yet to see it so I don't know if its nice enough to fix or just part it.
I'll know soon enough.
Is there websites more geared more toward them? (Not that here isn't good)
I guessing parts are scarce.
The 215 could be coffee table material or maybe I will luck out?
If you get it here's an extra 215 over in Lakeview.
http://klamath.craigslist.org/pts/4736228110.html
John
John
Be aware that while the 61-63 cars have a lot in common, the 63s use many one-year-only parts, including the steering linkage, brakes (63s use self adjusters), and obviously sheet metal.
this site is for 61-63, very slow but i stop by most days. http://oldsjetfire.com/
Awesome thanks!
I was surprised to see the shifting pattern. If I run the 215 I will upgrade to a 4speed auto or a 5speed stick (we'll see)
Don't be. That was normal before the 1964 model year.
The modern GM automatics require an adapter plate (sold by D&D) and trans tunnel mods to clear. The stock RH5 automatic is MUCH smaller than anything else out there.
The T5 is a nice swap.
It was used in many British vehicles. The TR8, Rover 3500, TVR, Morgan Plus8, MGB V8, and even the Land Rover 101 forward control all-terrain military vehicle. There was also the Leyland P76 version, with a taller deck. The latest Rover motors were built in displacements up to 4.6 liters (actually 5.0 for some TVR applications) and used cross-bolted mains. I've got one of these short blocks for my 62, as they are externally identical to the original 215. The British V8 website has much information on interchangeable parts. These are referred to as BOPR motors (Buick, Olds, Pontiac, Rover).
The Rotohydramatic 5 trans is unique to the Olds (Buicks used a Dynaflow) and is not one of GM's better automatics.
Buick did not use a Dynaflow in the Special. They used a transmission called a Dual Path. Mechanics at the dealership I worked at back in the day did not even attempt to work on them. The just replaced them with a factory rebuilt unit.
Could care less about the trans. My guess is its a core and probably hard to get rid of?
More important is who's building a 215? D&D has a cool website but lacks build info and results. Can one get a civilized 250HP?
I'm no numbers matching purist. Love to see a current EFI turbo ed version.
Megasquirt huh? Turbo ever cross your mind? As in modern turbo set up.
Actually, yes. The Rover EFI manifold has a plenum with the throttle body on the driver's side. You could mount the turbo above the passenger side exhaust manifold, run the compressor output through an intercooler in front of the radiator, and then plumb it to the throttle body.
If you are referring to the RotoHydramatic 5, it is unique to the 1961-63 F-85/Cutlass cars. Olds alternately called it a three speed and four speed AT, but the reality is that it only has three hard gear ratios. The alleged "fourth" speed is obtained through the fluid coupling internal to the trans, similar to the principle of the switch-pitch torque converter used on the 1964-67 automatics.
Had I read up before seperating the engine/trans I would have known there was no conventional torque converter. Was a very interesting site to see. I suspect it will end up in the recycle pile. I imagine demand for used RH5 is pretty low.
Reminds me of the DeSoto and others Fluid Drive semi-automatic PrestoMatic systems. It had 2 mechanical gears, a clutch, and an overdrive unit. Use the clutch to select low range or high range forward or reverse, take off, then let off the gas to get into overdrive in either low or high. You theoretically had 4 ratios, but only got to use either 1-2-4, or 1-3-4, depending on if you shifted, or the car shifted first. Use the clutch or not when you came to a stop. No parking pawl, parking brake on the drive shaft, so if engaged at speed the gear reduction could and would flip the car, and, when it went out, the standard wooden wedge was used to keep your car from rolling off when parked.
66ninetyeightls
January 10th, 2011 05:10 AM
