Exhaust
Exhaust
Just saw a video of my car at Kinney's exhaust in Texas. Its cool to see my car in videos before I owned it. I now know I have an X pipe with Magnaflow mufflers. I hate the drone I get with them and thought they were stock mufflers. Allen has provided a source for stock replacements and I intend on checking with that source. I have also done some research on magnaflow vs. walker though and would like some opinions on those. Any opinions would be great.
Ordered new system from Gardener Exhaust
From manifolds back including tips and all hangers and bolts. Aluminized with their Turbo mufflers. Thanks Allen for the number. They sound good on their website audio. It will be a while for them to make and ship but I will try to take pics of them when they arrive and post them as well as comment on the ease of install. The X pipe and mufflers I am taking off are still very good (except the drone). May sell them on the cheap instead of trashing. Someone may want the X pipe. Who knows.
Not cheap
Under 1100.00 delivered. I got the concours system with aluminized and if I remember correctly, a ceramic coating where the manifold bolts to the exhaust. The bolts and hangers are reproduction of originals with coating and rubber insulators. The pipes have all the indents and bends the originals came with. The mufflers have the square rolled seams. The tips are welded and the correct length. Check out the website. They make their own mufflers. Audio of the system can be heard there.
Gary, I'm glad you are happy with Gardner. Eric will deliver you a fantastic product and I'm sure you'll have no problems installing it.
For anyone else who's looking for an authentic exhaust system (same look and sound) as OEM? Gardner Exhaust. Here's Eric Gardner's contact information:
(845) 758-8003
(845) 758-8003
Garner Exhust Pics
Decided not to waste the bucks on rubber hangers. The members on here that say its the mufflers causing the drone was good enough for me. I got the Gardner Exhaust with the proper hangers and have pics of how its packaged. Very Well! As you can see in the pics a glass is included that I thought would look great filled with beer! I was going to have someone install this exhaust but saw some spots under there that could use some touch up so ,looks like I'll be under there myself. Easier to do before the exhaust is in. The gas tank straps are black (not sure if that is correct) and I may change them as well as convert some surface rust behind the rear bumper. The gas tank looks aluminized and I have to decide if I should change it too. Is there any one else out there that starts out with a small project that blossoms into a large project?
More info
Should also mention that the tips were wrapped and the pipes were in plastic sleeves to protect the finish. There is an installation instruction sheet as well as drawings from the original assembly manual. A questionnaire with self addressed envelope to voice your opinion. May take a couple weeks to get time to install but I will post a video of the sound (if I can upload it).
Only just about every time.
I've been recommisioning a '55 Olds 98 4-door Holiday hardtop that has been sitting for about 12 years.
Changing the dash pad became fixing everything under the dash that did not work. It's a New Mexico car so the dash pad was baked to a crisp, along with all of the vacuum lines. I had the heater core rebuilt to fix a leak as well. Took a huge rat or mouse nest out of the heater box.
So, now it has working wipers, w/s washers, Wonderbar radio, heater, defrosters, and even the clock now works.
Had a boat trimmer make me a replacement dash pad with the correct vinyl sourced from SMS Auto Fabrics.
Now onto the dried out front suspension..
Just kidding. We've all been there. I was just so anxious to hear the new exhaust but will have to be patient. I may clean up the area near the pipes, install the pipes and save the tank for winter. I could wrap them with the original plastic wrapping to protect from overspray when I remove the tank and freshen up that area. The tank area only has a little surface rust. Converter and encapsulate paint from Eastwood should do it.
Progress
Getting Gardner Exhaust installed Thursday. Eric at Gardner recommended a guy in St. Louis who turns out has a shop that does restoration work ( very meticulous work, as I remember him from my parts delivery days). I'll post pics and hopefully video of completed job.
Installed
Pics of Gardner Exhaust. Tips look uneven in pic but they are both same distance from bumper. Had to do alot of adjusting to get that way because who ever put the gas tank in rearranged the vent hoses/tubes.
Tip
Eric Gardner said GM extended them out some to prevent gasses from getting behind the bumper but I could adjust it if I want. I think I will try because I like them in tighter and Dr Oldsmobile most likely is not coming to my house. > Great exhaust system!
I'll suggest my own theory. We already know these chassis were assembled upside down on the assembly line and then flipped prior to marriage of body and installation of engine/trans/driveshaft. So I'm going to say it was easier for one guy on each side of the car to reach over and zip those clamps on with the hangers facing sideways. Whattaya think of that?
Makes more sense than speed bumps. The muffler body or drive shaft would hit first. Gardner supplies the page from the assembly manual that shows assembly. They even label the parts for proper alignment during assembly. Great service.
Was very happy with Pete Rizo's shop. Father and daughter shop. He lived up to his reputation and she had me at hello. Everyone treated me like family. Highly recommend his shop.
2blu442
March 7th, 2014 06:09 PM
atkinsom
May 29th, 2013 06:39 PM
65OldsDelta88SuperRocket
October 27th, 2011 09:16 PM
