u joint help please
u joint help please
I've got a 69 cutlass with the type O rear end. Just picked up a nice chevy 12 bolt out of a 69 chevelle. My u joint is not mateing to the yoke on the 12 bolt chevy rear end. Can anyone tell me if theres a different u joint I need to use or do I need to buy a whole new yoke and u joint? Ive looked over some other threads on this but can't find an answer. Thanks
They make a u-joint to do what you want. I've found them in local NAPA stores. Tell your favorite parts store what you doing and he should be able to come up with it. If I remember right Oldsmobile is longer across and may have larger caps. Then the chevy is shorter across and possibly smaller caps.
John
John
Yes. The caps are larger not fitting into the chevy yoke. My local part store kids don't know anything unless its a Honda. hopefully someone here can give me a part number of what exactly I need.
Brian Trick posted the part number for that conversion u-joint a while back. I couldn't find the part number but a web search revealed you need a 1310 to 3R conversion joint.
https://classicoldsmobile.com/forums...ft-length.html
Edit: part numbers on this site
http://www.dennysdriveshaft.com/p201...reaseable.html
From what I found, the # for the U joint you need is 3130 for the greasable one.
cluelesscutlass
August 18th, 2011 01:56 AM
defiant1
October 29th, 2010 12:41 PM
