ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > General > General Discussion
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old July 21st, 2008, 01:25 PM   #1 (permalink)
geckonz08
hot tanking
It seems to me ,from reading only,that after an engine is hot tanked we are generally accepting of the fact that all galleys are clean . The consequences of this NOT BEING SO could ,I imagine ,be fairly dire.
It also appears that the common agent used in the cleaning process is Sodium Hydroxide .
Does anyone recommend a further 'home'cleanup with a water blaster after a dipping in NaOH ??
Or am I being paranoid?????
Anyone got any bad experiences in this line ??
mike
geckonz08 is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old July 21st, 2008, 01:52 PM   #2 (permalink)
Danny Wiseley
DEFINITELY!!!
You can't get it too clean. The Sodium Hydroxide soak is just one of the steps in cleaning a block.
Run a brush through every oil passage, and wash the whole thing with soap and (preferably HOT) soapy water, until it passes a "white glove" test!
Danny Wiseley is offline   Reply With Quote
Old July 21st, 2008, 02:47 PM   #3 (permalink)
don71
feed the pig
don71's Avatar
Yea, I agree. Time spent cleaning won't be wasted. Being anal retentive will pay off in this exercise. I hav'nt had any bad experiences....yet.
You might follow up after the hot soap water with compressed air. Some of usual shop solvents like wd40,brake clean or paint thinner after that.This will help deal with a little flash rust that often appears quickly. You could reverse this procedure, use the solvents first, then hot soapy water. Either way is fine.
BTW, the little oil gally brushes are available in a set, from the usual mail order-internet- catalog stores.
__________________
1971 Cutlass S Holiday coupe-455/th400 3.23
Oldsmobile they were meant to be driven.
don71 is offline   Reply With Quote
Old July 21st, 2008, 03:01 PM   #4 (permalink)
Olds64
Landyacht Club President
I used either Simple Green and hot water or Comet and hot water to clean the engine after it is hot tanked. Apply a thin coat of oil or cosmoline to the block with a wire brush after cleaning it to prevent flash rust. Then when you paint it, you can clean it again with denatured alcohol.
That is what I have done and it works well.
__________________
Ferris, my father loves this car more than life itself... Apparently, you don't understand! Ferris, he never drives it! He just rubs it with a diaper!
Cameron Frye Ferris Bueller's Day Off 1986
Olds64 is offline   Reply With Quote
Old July 21st, 2008, 05:50 PM   #5 (permalink)
joe_padavano
Super Moderator
You are completely correct. Normal engine building practice is to use a gun cleaning kit to clean out the oil galleries and other passageways in addition to a hot water overall washdown. I should also add that I've found the disturbing trend lately that machine shops are replacing their hot tanks with steam cleaners. I suspect there are two reasons for this. One is the environmental impact of the caustic cleaner in the hot tank and two is the large number of aluminum blocks and heads on newer cars, which cannot go in a conventional hot tank.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
joe_padavano is offline   Reply With Quote
Old July 21st, 2008, 08:32 PM   #6 (permalink)
geckonz08
Smile
To All the above thanks --all good info to me n hopefully others I heard about the steam cleaning "substitute "if we can call it that -visions of the engine disappearing to the workshop beyond,out the back door and a steam blaster being reclassified as hot tanking .I am going to be so anal !!!!! cleaning this block n heads
You may find the below link interesting --electrolytic cleaning
http://users.eastlink.ca/~pspencer/n...ctrolysis.html
Old July 21st, 2008, 08:54 PM   #7 (permalink)
J-(Chicago)
Seasoned beater pilot.
J-(Chicago)'s Avatar
I tried the electrolysis thing with my bumper impact pistons. Takes too long.
I had it in the bath for 5 days and the piece was still a mess.
Dropped the other in a bucket of white vinegar and got it done in 2 days.
Sandblasting is still the trump card in my opinion.
__________________
I'd rather have a numbers matching poker hand.
J-(Chicago) is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Hard to start when hot... cbogartjr Big Blocks 17 July 21st, 2008 12:31 PM
Difficult to start after engine is hot. New'n72 Electrical 68 July 19th, 2008 10:07 PM
How hot is to hot? Oldsproject Big Blocks 7 June 21st, 2008 08:03 AM
wiper motor 'hot" Pfiffle Electrical 1 April 3rd, 2008 05:01 PM
Heater blows hot air. Sometimes. Gert3116 Small Blocks 4 January 13th, 2008 12:48 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
