Springy thingy?
Old August 12th, 2012, 06:36 PM
ralsy's Avatar
Springy thingy?
What is this springy thingy in the back of my Rochester 4brl, and what does it do????????
ralsy is offline
Old August 12th, 2012, 06:40 PM
That's the hot idle compensator.
Under the cover is a bimetallic strip with a rubber end, which closes an air bleed hole that goes into the manifold.
When the engine gets hot (such as idling in traffic on a hot day) the strip deflects, opening the hole, and allowing in extra air to lean out the mixture to prevent an over-rich condition.
The spring there is a button you can use to hold the valve closed when tuning a hot engine, so as to make your settings accurate.
See your '68 Chassis Service Manual.
MDchanic is offline
VI Cutty
Brakes/Hydraulic Systems
June 24th, 2014 06:38 PM
GRIFFER
January 10th, 2011 06:08 AM
auto_editor
December 14th, 2010 09:26 AM
labrats804
May 30th, 2007 08:30 AM
Quick Reply: Springy thingy?
