looking for 1966 hidden vin locations
Old September 13th, 2011, 12:08 AM
Ben
RAMBOW's Avatar
Question looking for 1966 hidden vin locations
Trying to help decipher a friends car & we like to see if his frame has been swapped or not.
Can anyone tell me where the hidden vin stampings on the frame were in 1966 & 67? I know i'll have to use mirrors and wreck my back and still may not be able to see them, but its worth a try.
Thanks-
Ben
RAMBOW is offline
Old September 13th, 2011, 06:08 AM
dmiron's Avatar
I know my 66 442 was on the top of the frame just in front of the left rear wheel. It would be close to where the frame begins to go straight. I saw it with the body off. Hard for me to believe you can see it with the body on.
dmiron is offline
Old September 13th, 2011, 02:00 PM
66luvr's Avatar
Haven't looked on the 66, but I had a 64 Skylark I looked at. As stated before it was on top of the frame, mine was around the rear of the door opening on a comvertible. Like you said, good light and mirror, I found it.
66luvr is offline
Old September 14th, 2011, 07:02 AM
dmiron's Avatar
Sorry. in my reply I indicated the number was in front of the left wheel, however I meant the right rear wheel.
dmiron is offline
Old September 14th, 2011, 08:44 AM
66-3X2 442's Avatar
The vin # on a 66 is on the left drivers side frame rail. It can be either behind or before the kick up for the rear axle. The part #'s/date codes are on the left vertical side of the frame near the rear. The vin #'s are on the top area and can be seen with a mirror.
66-3X2 442 is online now
Old September 14th, 2011, 08:54 AM
Ben
RAMBOW's Avatar
thanks guys.
I will jack up mine and see if i can locate it- then when he returns in a few weeks i'll try and see if i can find his.
RAMBOW is offline
Johnd
Body work
December 27th, 2014 11:40 AM
67442nut
October 6th, 2014 09:30 PM
HoustonS88
June 1st, 2011 12:02 PM
kevdog442
March 11th, 2009 06:51 PM
Quick Reply: looking for 1966 hidden vin locations
