Oldsmobile Vin Decoder Site
Old June 11th, 2011, 02:44 PM
gtdrvr's Avatar
Dont know if this has been posted before or not but here it is
http://www.v8cars.hu/oldsvin/decode.php
gtdrvr is offline
Old December 28th, 2011, 08:16 AM
nitrojunkie1029's Avatar
thanks very much it helped alot! do you know where i can find out what gear ratios are in my rear end?
nitrojunkie1029 is offline
Old December 28th, 2011, 10:20 AM
NôôB
sicky olds's Avatar
I like to use that one myself, Especially when looking on sites like autotrader classics and ebay , helps out with fake VINs for the most part
sicky olds is offline
Old December 28th, 2011, 11:33 AM
1974 DELTA 88
AZ455's Avatar
I'm sure we could decode it if you post the axle code. The code is stamped on the passenger side axle tube (I believe this may vary by year?). It is close to the diff, and the code faces the front of the car. It may take some serious scrubbing to expose it.
AZ455 is offline
Old December 29th, 2011, 08:53 AM
ok i'll try that, thanks
Old December 31st, 2011, 10:54 AM
i got a few codes from the diff and the axle tube right where you said it would be. the numbers on the diff are 1234496, this was found on the oil cover. and 1235197 this was found on the passenger side of the diff on the side sort of of the pumpkin. the one on the axle tube was this SA 021 1, and it could have possibly been 0 SA 021 1 idk anything aobut these numbers or what they are supposed to look like but thats what was there. if you can get anything out of these that would be great. thanks alot
Old January 1st, 2012, 08:08 AM
gtdrvr's Avatar
need to check the code on my diff also as I believe it is geared low when I m in third i feel like it should have another gear.
gtdrvr is offline
joe_padavano
Tech Editor's Desk
25
July 6th, 2015 12:22 PM
1970cs
January 18th, 2012 05:56 AM
decodethis
December 17th, 2011 03:18 PM
Jamesbo
November 21st, 2008 04:34 PM
65 Dynamic 88
February 26th, 2008 04:57 PM
Quick Reply: Oldsmobile Vin Decoder Site
