'70 olds 442 power steering hose clamps
Old April 27th, 2011, 11:29 PM
DRXOLDS's Avatar
Does anyone know what the correct crimping tool for oem hoses for the power steering pump hose clamps ?
Thanks !
DRXOLDS is offline
Old April 28th, 2011, 06:08 AM
"Car"mudgeon
GAOldsman's Avatar
That would most likely be hydraulically pressed/crimped on by a business that specializes in making up hydraulic lines. Just google "hydraulic equipment & supplies service & repair" with your area code and it will show businesses around you that can do this, however it may be just as cost effective to buy a replacement hose already made up specifically for your vehicle. Hope this helps.
Scot
GAOldsman is offline
Old April 28th, 2011, 06:13 AM
Rickman48's Avatar
Just replaced both on a BB '70 Chevelle - got them from The Parts Place and they were perfect stock replacements.
Rickman48 is offline
Old April 30th, 2011, 07:05 PM
defiant1's Avatar
Do you have to use the crimp style hose clamps for the power steering hose? Or will a standard hose clamp work?
I ordered the factory clamps but don't have the tool to crimp them properly.
d1
defiant1 is offline
Old April 30th, 2011, 10:55 PM
DRXOLDS's Avatar
Well....the clamp tool is called a Pincer Tool . Also the clamps are called "Ear Clamp" , or "Pinch Clamp" ....They are one use only.
Hope this helps... Thanks for you your response!
DRXOLDS is offline
Old May 1st, 2011, 04:39 AM
RALLYE KID's Avatar
I got my power steering hose clamps and crimping tool from year one
RALLYE KID is offline
Old May 1st, 2011, 04:45 AM
My442's Avatar
Those clamps are called Oietker clamps.
A dull pair of tile nips work perfect....
My442 is offline
Old May 1st, 2011, 05:56 AM
DRXOLDS's Avatar
Power Steering Hose Clamps
Thanks for the input from all. It will look much better with the OEM clamps !
DRXOLDS is offline
Old May 1st, 2011, 06:36 AM
defiant1's Avatar
Those I think I have. Thanks for the tip.
d1
defiant1 is offline
Old May 1st, 2011, 07:52 AM
Shoveling Snow
Hairy Olds's Avatar
This is the tool to do the job properly. K-D #424.
I also sell these type clamps for the power steering hose and the 1967 442 heater hose clamp - manifold to heater core hose.
Hairy Olds is online now
Old May 1st, 2011, 09:10 AM
DRXOLDS's Avatar
Thanks so much.....Tools are 99% of the job. I sure you know you just can't have enough (correct) tools !! DRXOLDS
DRXOLDS is offline
Old May 1st, 2011, 09:34 AM
DRXOLDS's Avatar
Where can I buy that tool ? Is it the same one they use for CV joint / boot clamps....
DRXOLDS is offline
Old May 1st, 2011, 09:51 AM
Certifiable car addict...
GTI_Guru's Avatar
that is the same one for CV boot clamps from the look of it. Dunno if you can get one at the local parts store, but if you can flag down a snap-on/mac/matco/cornwell tool truck, they should probably have one. Talk to your local auto shop(s) and see what the schedule is for the tool guys that make the routes in your area.
there's ones online too:
http://www.toolking.com/kd-tools-395...21635333&c_j=1
This one is at Advance auto parts if there's one of those chains near you
http://shop.advanceautoparts.com/web...=00-19965648-2
Also, check with AutoZone. They have a tool rental program that could set you up with one possibly.
-Jeff
**EDIT**
Just found this one cheaper than the previous one. 2nd one down and 7th one down. I recommend the 2nd one. That's the one I have in my toolbox. it's a heavier duty style, and you can use 1/2 drive ratchets or breaker bars for extra leverage if needed for some of the really stiff clamps.
http://www.shoptoolsshoptools.com/sh...CV+Joint+Tools
GTI_Guru is offline
197064buickspec
July 15th, 2019 04:28 AM
ROCKET VAPOR
July 10th, 2012 08:50 PM
Del70
October 29th, 2010 09:15 AM
bobb
October 20th, 2010 03:19 PM
fjross
November 17th, 2009 05:40 AM
Quick Reply: '70 olds 442 power steering hose clamps
