Is this carburetor original
Old February 24th, 2017, 01:50 PM
jc1671's Avatar
Hi fellows - how can I tell if my carburetor is original? I see the #7040253 then 1307 on it, not sure how I can research originality so any help is appreciated. I am attaching a picture with the number.
If original I would like so sell it so let me know what is the ball park value for something like this. Thanks.
jc1671 is offline
Old February 24th, 2017, 02:17 PM
lemoldsnut's Avatar
THat is a good number but looks like a restamp
lemoldsnut is offline
Old February 24th, 2017, 02:28 PM
jc1671's Avatar
sorry for the dumb question but what does Restamp mean? Do you mean someone actually stamped over these numbers?
thanks for the reply.
jc1671 is offline
Old February 24th, 2017, 02:34 PM
lemoldsnut's Avatar
Yes in the picture it has a mark after the last number which does not look correct to me. Others might chime in on this. But that usually indicates a carb that has been stamped over in my knowledge.
I am looking for that number carb. Not sure I want a restamp.
Old February 24th, 2017, 03:07 PM
stevengerard's Avatar
it is hard to tell from that image - definitely looks like the plating has been removed which is also a sign of a re-stamp - but hard to tell if there is less material. Also there is no factory code e.g. UA or RK after the date number.
stevengerard is offline
Old February 24th, 2017, 04:05 PM
mrolds69's Avatar
Take more pics of the top, bottom and 2 sides. There are people here who can tell you if it has the right parts on it for that number. Then you can get a better idea of what it is.
mrolds69 is offline
Old February 24th, 2017, 06:51 PM
Quadrajet Power's Avatar
There is no plant code stamp on it, which would be 2 letters.
The 1307 indicates a production date of 130 the day of 77. If it was an original production unit, that 4 digit code should end in 9 or 0 for a 69 or 70 production year.
Quadrajet Power is offline
Old February 25th, 2017, 10:56 AM
marxjunk's Avatar
looks like its a its a "real" carb to me...its a service piece..as Mark said no pick code..and that "mark" is 100% right..its the gang stamp tool thats struck the pad...seen it many times on service pieces many many times..a google would bring it up 100s of times..its a known defect in service carbs
and whos gonna restamp a desirable carb with a 1977 date?
low production carbs, and many service carbs are batch stamped by hand..that 77 date time line is common...77-78 is a very common date for service pieces..it was about the last batch they made
marxjunk is offline
Old February 27th, 2017, 07:28 AM
jc1671's Avatar
Thanks for the feedback, I am attaching a few more pictures to hopefully put this to rest. Let me know if this helps any, thanks again.
jc1671 is offline
Old February 27th, 2017, 07:36 AM
The throttle shaft, vacuum brake and rod, and base all appear to be correct to me.
yeahbuddy
June 1st, 2010 05:38 AM
Gaz Hog
October 17th, 2007 07:26 AM
TheRuss
July 25th, 2007 01:22 PM
olds307owner
May 23rd, 2007 09:01 AM
ViceGuy
March 25th, 2007 01:43 PM
Quick Reply: Is this carburetor original
