1967 olds toronado deluxe
Old February 23rd, 2017, 05:10 AM
Rayme's Avatar
Does anyone know where I can get a reproduced window sticker for my car?
Rayme is offline
Old February 23rd, 2017, 06:37 AM
If you are looking for a copy of the original window sticker to verify what equipment was on the car, they don't exist.
If you are looking for a reproduction window sticker with whatever options you want on it, why?
joe_padavano is offline
Old February 24th, 2017, 04:48 PM
Gary
VC455's Avatar
I got great service and a nicely done window sticker replacement from a person on this site. He has the correct paper for the year and needs the following information:
Options
Interior and exterior colors
Assembly plant location
Selling dealer name
VIN
Assembly date
When I ordered, the cost was $46 for a laminated copy and $10 for an unlaminated.
Contact J Ramsey at 4speed442@sbcglobal.net
VC455 is online now
Old February 25th, 2017, 04:38 AM
Rayme's Avatar
I have a 1967 olds tornado and it has the 425 385 hp engine. When I pull it into my garage and shut it down and go upstairs the smell of gas is REALLY bad. I don't see any leaks. What could this be
Rayme is offline
Old March 18th, 2017, 06:32 PM
tds
tds's Avatar
I have the same issue. I have two vent lines that are attached to he gas filler pipe. I'm sure that is where the gas fumes come from. Don't know if it is OK to connect the hoses together to create a loop. Any ideas anyone?
Thanks,
Tom
tds is offline
Old March 18th, 2017, 06:42 PM
Inspect the fuel system from the cap to the carb. Look for old and cracked rubber lines that won't necessarily create a puddle but weep enough fuel to stink up a garage and create starting issues. Also look down into the car and see if fuel is dribbling in the throat after you turn it off.
oldcutlass is offline
Old March 19th, 2017, 07:48 AM
tds
tds's Avatar
I had the gas tank "rebuilt", and all the gas lines replaced, but I have not looked down into the carb. Thanks for the tip!
tds is offline
Daniel Marsh
February 14th, 2015 05:04 PM
mid60soldsfan
January 31st, 2015 02:48 PM
my67toro
April 1st, 2013 10:35 AM
dlinderm
August 16th, 2011 09:12 AM
my67toro
December 17th, 2010 07:51 AM
Quick Reply: 1967 olds toronado deluxe
