crossmember swap
crossmember swap
finished installing the 1973 duel hump crossmember in the 76 supreme today .went in very well with no drilling. all bolt holes lined up perfectly .the biggest challenge was reinstalling the e-brake cable. the passenger side cable guide that goes in the crossmember didnt quite fit like it should so i had to modify it resulting in the e-brake cable being much tighter than it was originally.had to run cable on top of the crossmember on the drivers side as it was under the original crossmember .backed off on the tensioner to readjust the e-brakes.i wonder if having the 73 cable guides would have helped ?
it seems to be fine. would you or anyone else know if the correct routing is above the crossmember on the 1973 cutlass .havent been to sucessful finding a good image of it
no, i dont remember..its just been so long since i had one, its just not in my memory
when i get stuck like that, i google things like 73 cutlass click on images and look til i find it, and believe me its there..just takes time..remeber by 73 the stuff got really generic across all the lines..so any GM A body could be a match
heres the search i used for google
73 cutlass double hump cross member
exactly 1 minute turned this up..theres a pic..its a 73 malibu..but bet its the same..theres detail pick of the crossmember and the brake cables
http://www.bangshift.com/forum/forum...arlo-rip/page4
heres another..with an aftermarket cross..but it shows the routing
http://www.g3gm.com/t574-dual-exhaus...members-custom
and another from the bottom looking forward you can see the cables
http://www.g3gm.com/t10522-the-rusty-carlo
this search was 73 cutlass frame
and with the body off
http://www.elcaminocentral.com/showthread.php?t=184634
