| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Vendor Directory |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
cant get car to start
Ok so my car(1971 olds cutlass s) was sputtering a little bit and found out it was the exhaust so i replaced the donuts. Then some spark plug wires werent firing so i replaced those and the spark plugs. When i was replacing the wires i forgot to write down which wires went to which connector on the distributor and now it wont start. It turns over but wont start up. Ive looked up the different ways they go and some say clockwise and some say counter clockwise. Well i have tried both and still now luck. Some body please explain whats going on.
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
Oldsmobile distributors turn counter clockwise. Did you check and see if you are getting spark?
#3 (permalink) | |
Quote:
__________________
Joe Padavano 62 F-85 Deluxe wagon 64 Jetstar 88 Conv 66 442 L-69 Conv 68 W-30 69 H/O 69 442 70 W-30 72 442 84 Custom Cruiser 86 Caprice wagon (w/307 Olds) |
#4 (permalink) |
Thanks so much for your guys help
all the firing order diagrams on the internet were all wrong so when i did what you guys said it started right up ))but now when i take it for a drive and give it gas it basically idles for about 2-3 seconds before it gets going and it never use to do that. |
#5 (permalink) |
Hot Rodder at heart Administrator
Did you re-connect the vacuum to the advance actuator on the distributor?
__________________
Dan '77 Cutlass Supreme '46 2 door "The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB. |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| To start or Not to start? | rrielley | General Discussion | 5 | September 1st, 2008 04:00 AM |
| Ignition - won't start | justinj | Electrical | 16 | August 26th, 2008 01:59 PM |
| Engine will not start | D Appeldorn | Electrical | 4 | April 24th, 2007 01:52 PM |
| slow start | 69olds350 | Small Blocks | 0 | November 7th, 2006 08:01 AM |
| 1977 Olds 350 with Rochester 4bbl - car dies after first start... | emarkay | Small Blocks | 8 | December 8th, 2004 09:23 AM |
