Uhv
Uhv
Picked up a UHV setup off ebay for the 67.
Coil, box, distributor and cap. The search function yields that Mr. Skaff is working on a system, and Mr. Witt is the local expert on them. Ebay offers a Vette guy's service to replace the Germanium guts of the amp with modern circuitry, and I can have another module put in to drive my tach (corvette's are cable driven like a speedo.)
It's in good shape, but needs restored. Missing one plug off the harness. Needs a rotor, unless this thing runs off of so much PFM it just arcs up there. Same rotor part number?
Should be fun.
Should be fun.
Moved it for you. Congrats on the purchase. I've got a setup I removed from a 1967 Toronado many years ago and have thought about putting it in a 1967 442 project car. Just for fun, would you post pictures of it?
John
John
I sent mine to Dave Ray,"Distributor Dave". He converted it to HEI. The only thing in the box is an HEI module. I sold the guts of the box to Chris Witt. The distributor was actually a points dist, so no big loss. Just got my engine running a couple of weeks ago, and it runs and sounds great. Good oil pressure, runs about 185 degrees in the garage with a fan blowing through the radiator. I bought 2 of the original red dist caps on Ebay awhile back and painted my coil red to match. It will look like UHV but its the newer HEI. Seems to work great. Daves charge was $205.
John, sure, let me get back home and I will.
Steve, that might be an option.
Joe, that seems like a good idea. One place online seems to like to mill out the housing to mount it better. I will get an HEI module and see what I can do.
I was under the impression that the shaft had to be turned, but I really dont know that, or what is required to do the conversion. Dave cleans it, puts in new bushings/bearings, new vacuum advance canister, new cap, gear if needed. He will keep it looking original, or polish it what ever you want. Probably more to polish it. He sets it up to your engine build, ie. headers, cam, carb, etc. Adjustable advance or standard. Mine has the HEI reluctor and an MSD pick up coil. It works great so far.
I just did the HEI module conversion for a friend's 68 W-30 UHV setup. We used the original UHV distributor with no modification. I removed the board from the original UHV module and made a small aluminum plate with holes drilled in it to match a couple of the mounting locations of the original board. The HEI module is mounted to the plate with heat sink compound between it and the plate.
I also modified the wiring harness to utilize the module. From the outside, you would never know the original UHV board was not in the housing.
Very cool set up. Was the original wires coming from the box warped in a black insulation like the rest of the wiring harness? If so you might want to copy that so that it is indistinguishable from the original set up.
Thanks or sharing very cool
Bernhard
Bernhard
Yes i believe the original wires were wrapped, I still have them i think, ill check that out. Very easy to wrap them, and make um look original. The $205.00 was for Dave to convert my points distributor. He didnt charge any more to put the module in the UHV box. Sounds like Koda has the UHV distributor, I dont have any idea if a HEI module will work with it, but it seems Joe P. is saying it will, that might be an easy conversion he can do himself.
I think the $205 was very fair for the amount of work and parts required.
I also like the reluctor he used in the conversion. Did he use a MSD pick up coil?
How much do the red caps go for and do they still come up?
Bernhard
Bernhard
