Battery Draw/Under Dash Sparks
Hi...Paul here. My battery needs to be re-charged about every 10 days. I must have a bad ground or some other problem that is drawing down the battery. I was under the dash and I accidently touched the antenna lead to the glove box metal bracket and there was a spark and it blew out the courtesy light fuse. I would suspect what happened is associated with my battery problem. How do you suggest I go about fixing this electrical issue? Any help would be appreciated. Thanks.
Sparks are bad, M'kay.
Personally, I would suggest you invest in a Power Probe w/ tracer. And I wouldn't leave the battery hooked up were I you. You're going to have to trace your wires to wherever you've worn through the insulation. Did it blow any fuses?
The ground side of the battery is already connected to ground. Nothing you do on the ground side will affect battery charge at all. Any discharge comes from a short on the HOT side. Find that.
Both the dash and the outer coax of the antenna lead are ground. More importantly, there isn't any measurable voltage in the antenna lead. I suspect you pinched something else in there, like the glove box light feed wire.
Try getting a test light, hook the ground directly to negative post of the battery then touch the tip to metal under the dash. If it lights up, start pulling fuses and see if one of them makes the light go out. If that works that will tell you which circuit to examine. You will have to extend the wire going to the battery.
oldspackrat
January 1st, 2015 06:23 PM
