1970 442 W30 electrical problems
Old October 27th, 2008, 04:00 PM
daniel's Avatar
i have a 1970 442 W30 that will start with the altornator plugged in, but when i go to shut the car off, it wont stop running, the car will start with the altornator unplugged, and will shut off with the altornator unplugged, but eventually my battery will die, from not having the altornator plugged in. what can i do to fix this?
daniel is offline
Old October 27th, 2008, 10:52 PM
Just the facts...
BILL DEMMER's Avatar
i would start with tracing the ignition wiring. the ignition circuit power supply is cut-off by the ignition switch, which then is supposed to ground the power wire to the ignition coil + terminal.
bill
BILL DEMMER is offline
Old March 11th, 2009, 01:33 PM
stellar's Avatar
sounds like 1 of 2 possible things. Either way your alt is feeding ign circuit. Either the #1 wire is shorted to ign feeding coil or someone needed a wire that was powered with the key on to feed the #1 alt wire and spliced into the ign wire. Does this car have an alt idiot lite that isn't working or is it OE with guages?
stellar is offline
chasman414
June 25th, 2020 07:05 AM
Hurst/Olds 73/74
October 16th, 2014 06:22 AM
bpnoel
August 27th, 2010 08:11 AM
65topless
July 6th, 2007 01:55 AM
jf857
April 28th, 2006 07:24 AM
Quick Reply: 1970 442 W30 electrical problems
