Sport Steering Wheel - Horn Help
I just took off an old Grant 13" steering wheel, I am putting on a Stock Sport Steering Wheel 15 1/2 " (1970 - 1977)
I have the hub, the horn contact and the horn button for this steering wheel.
I think I am missing a contact of some sort for the horn to work.
I have two different plastic horn contacts with the copper strip that sits under the hub, the one I took off has the notch for the spring loaded wire. from what I can see this set up will not work on this steering wheel and hub. the other one I have has no notch for a spring loaded wire. Does this just have something that sits in there to make contact with the horn button when depressed?
Any help is appreciated, thank you in advance...Todd
Hi Todd
I know there's an old thread on this, but I can't find it. The first picture is what I think your needing, and the little spring/plastic ring/small brass piston is available repop.
But let me take it down to the blinker switch and show the pieces needed.
This is fantastic thank you very much for the pictures 2blu. I found the black piece, brass piece and spring. my black piece does not have the little nib on it to twist into the plastic horn contact, does that matter? So this brass piece has power running through it and touches the underside of the 3 screwed horn cap retainer which activates the horn once the horn button is pushed which grounds the circuit....correct?
After removing the Grant steering wheel which was on the car when I got it I can see that I am missing the two metal round caps held on by the C-clip and two screws. My car is a 1968 Cutlass S so there is no steering lock so maybe these plates were not used or do I need them?
Thank you again your help is greatly appreciated....Todd
Let me just clarify that this photo is not how the eyelet and spring get installed.
The spring goes in the hole first, followed by the eyelet (big end down), and finally the plastic retainer ring. The small end of the eyelet needs to be spring-loaded against the "L" tab on the bottom of the horn contact ring once the ring is attached to the steering wheel hub.
Thanks Joe. I photographed the disassembly from a parts car years ago and didn't realize it was in wrong. I'll try to get the correct picture to replace this one and avoid confusion in the future.
Since Todd is working on a 1968 column, is he correct that he won't have the two plates?
John
John
It is Done !!!
I got it done this morning, it didn't feel 100% right putting it together but hey it is working so.......
Thank you for all your help : )
Best Todd
(pics attached of my 1968 Cutlass S with new steering wheel)
Best Todd
I know this is an old thread but I have a 69 cutlass and I need to know how to get a replacement part. On picture 3 and 4 I shows a white plastic part. Mine has this part with the long shaft the sticks through broken off. I have tried several times to glue it back on without success. Does anyone know what this part is called and where I can buy a new on? In your photo it has an 8 s stamped on it.
Actually, it's called a TURN SIGNAL cancelling cam, as the two bumps on the sides are the cam lobes that cancel the turn signal after you turn the wheel. The same part is used by Chevrolet, so they pretty much grow on trees. The Dorman part available at just about any auto parts store works fine.
Maybe somebody more savvy than I can clarify the years these were used, but I think GM superseded the original, and intended for all replacements to use the later style.
I have the friction fit one in my 68 Cutlass as that is the only one I had. My issue is my cancelling cam does not seem to work on one side. I just had the car aligned and I need to take off the steering wheel and put it back on straight. Anyone know why my cancelling cam is not doing its job?
If all of that checks out, there is probably a problem in your switch. There are a couple of torsion springs in there that can wear out or become weak or dislodged. Replacement switches are available, though not cheap. Many here have rebuilt their switches with new springs, which are also pretty easy to find.
My 1968 Cutlass does not have the locking plates as there is no locking steering on a 68 and there is also no master spline. I think this is where the problem lies. I looked at the signal switch springs, and they are there and operating well manually. The cam will cancel if I spin this cancelling cam around by hand, but not when I am driving. You said it needs to be at 9 oclock? Mine is at 3 oclcok, could this be all that is wrong? I just need to pull off the hub and spin it around to 9 oclock?
thanks Todd
thanks Todd
Duh!! You're right of course -- I'm used to working on the '69, which would definitely have some differences, like the locking plate. On vehicles with the locking plate, it restricts where the cancelling cam tower can be located. On the '68, I'm not sure what determines this. Do you have the factory service manual or the assembly manual?
The '68 may indeed need to have the tower at 3 o'clock, but it definitely does need to be in the correct orientation and to rotate with the steering shaft without play. Once assembled, the cancel cam must be locked to the steering shaft in order to work. If the '68 accomplishes this only by the fastening of the hub, then is it possible that the hub could be in the wrong orientation?
The signal switch is fastened to the steering column housing and remains fixed, while the cancel cam rotates with the steering shaft and wheel. The signal switch has plastic followers which are operated by the lobes on the back side of the cancel cam. Those followers can also become worn, broken, or weak. More importantly, if the cancel cam lobes don't hit these followers, cancelling won't happen.
I'd have to do some research on the '68 to see how it's assembled.
Thank you we are thinking ion the same way but I do not have any pictures of how this should be assembled. It was in the 3 oclock position but it had a grant steering wheel on it That shouldnt matter though as far as the cancelling mechanism its either in correctly or not. I dont trust the last person who assembled it as it was pretty rough. Maybe it needs to be I nthe 9 oclock or maybe it is just worn out. However I did look for the bumps on the back of the cancelling cam and they do seem to be there. Maybe it is the signal switch that is attached to the housing that is worn out. Its weird because once in a blue moon it will cancel.
I'd agree, the steering wheel shouldn't affect the cancelling. FWIW, I had similar issues with one side not blinking. The previous owner was convinced that the problem was in the trunk harness, so I replaced that and the problem persisted. Once I replaced the turn signal switch, the problems disappeared. I can now even shut off the hazards with the button (before I had to wait until it decided to shut off by itself).
If you haven't done so already, go to wildaboutcarsonline.com, register, and download all the free manuals for your car. They should have the factory assembly manual and the factory service manual, one or both of which will show you what should originally have been in your steering column. That's where I'd start, and it could eliminate a lot of questions. A picture or diagram is definitely worth a thousand words.
Leadfoot thank you for the link for the manuals this help tremendously. I just got home from Ruidoso as there was a car show there in NM. I barely made it there and home (El Paso TX) with my carb acting up terribly. Joe both those springs are in tact that was the first thing I checked...Thanks all...Todd
Lady72nRob71
September 13th, 2010 05:45 AM
