ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Electrical, Interior, and Other > Electrical
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old August 3rd, 2008, 10:59 PM   #1 (permalink)
blunce
Junior Member
Wire from coil gets REAL hot
I just dropped in a used '69 350/TH350 into my '69 Cutlass and have got it running, however I noticed real quick that one of the wires from the coil (not the main spark plug wire that goes to the dist.) gets super hot as soon as the key is turned to the ON position. There are two smaller wires that come from the coil; one (yellow) goes to the starter (this one is fine) the other (black) goes to the firewall connector then inside and up to the ignition switch I believe. This is the one that gets hot enough to catch fire.
I have a wiring diagram for a '68, but that diagram says that wire should run straight to the fuse block which on my car it is not. Also there are no fuses burning out during this occurence. I'm quite far from an electrical genius so if anyone has any ideas, help, or '69 wiring diagrams, it would be greatly appreciated!
blunce is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old August 4th, 2008, 09:06 AM   #2 (permalink)
BILL DEMMER
Just the facts...
from what i gathered, there are 2 possibilities:
1 you're using a 6 volt ignition coil
2 the coil is partially shorted internally
bill
__________________
'67 CUTLASS 4-DR. W/425 & S.P. THM400 (NAMED "ERNIE")
'83 H/O #1339(STILL IN PIECES)
'85 PONTIAC FIERO SE V-6 4-SPD. BOUGHT NEW
'92 CHEBBY DIS-ASTRO (GAS PIG)
'97 GYRO METRO $HYTBOX (41.42 MPG)
BILL DEMMER is offline   Reply With Quote
Old August 5th, 2008, 01:05 AM   #3 (permalink)
blunce
Junior Member
Thanks for the help Bill. I got a new coil and installed it. So far with the key on for about a minute, no heat. Whereas before the wire would get too hot to touch in a matter of seconds. I have yet to start and run the car with the new coil as I have the heater core out of the circuit due to leaks. Will give it a go tomorrow. Thanks again! I was busy chasing wires before your help.
Old August 5th, 2008, 10:26 AM   #4 (permalink)
BILL DEMMER
Just the facts...
no prob!
glad you got 'er fixed.
bill
__________________
Old August 5th, 2008, 11:10 PM   #5 (permalink)
blunce
Junior Member
Final Verdict: SUCCESS!!! Thanks again Bill, it works like a champ. I'm so glad I don't have to mess around with figuring out some kind of wiring problem! Now on to the heater core....
Old August 5th, 2008, 11:56 PM   #6 (permalink)
BILL DEMMER
Just the facts...
Quote:
Originally Posted by blunce View Post
... Now on to the heater core....
you're on your own!
bill
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Is it live or is it memorex??? or a real 442 70vette 442 18 September 3rd, 2009 10:47 AM
6 cyl coil vs. v8 coil. 68conv455 Electrical 1 February 20th, 2008 03:36 AM
A real challenge - Block ID issue joninva1 Small Blocks 5 August 27th, 2007 05:03 PM
Is this 442 for real??? catonine 442 2 July 20th, 2007 07:42 PM
Its a real 442?? 442 Guatemala 442 6 July 12th, 2007 11:54 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
