| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
Junior Member
power problems
i got a 1968 cutlass 4 door 350 auto yesterday i got the heater to work and everything else worked fine until i turned on the wipers and shut the key off mid way up when i turn the key back on the wipers didn't work the heater doesn't work and the gen light is on. I don't understand what it could be. A fuse able link?
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
Welcome!!
It could be a fusible link, but maybe your ignition switch or a loose connection (or open wire) between that and the battery. Have a test light or volt meter? Follow the main 12V circuit from the battery to the junction block on the firewall to the fusebox to the ignition switch. Have a wiring diagram of the car yet? It will be very helpful. Laeving the wipers on in mid sweep would not have caused the problem - just was a coincidence.
__________________
-Rob Young 1972 Cutlass Supreme Convertible (442 clone) -"Lady" (My mistress...) http://www.flickr.com/photos/robsalbum/sets/ 1986 Cutlass Supreme Coupe - "Pristine" 1978 Ford (Old Faithful) a.k.a. "the Tramp" 1997 Cadillac STS (for sale - too many cars!) 1999 Harley Davidson Sportster - "the Freedom Machine" |
#3 (permalink) |
Junior Member
power problems
some one put a generic ignition in it so the some of the wires are not hooked up i need a wiring diagram for the car b4 it happened i hooked up the wire for the head light made the heater worked replaced the bulbs in the running lights after the light came on i looked on the alt and there was no ground wire i put one one it i need to get a volt meter i only have a test light they didn't hook up 3 wires from the original ignition
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| LS1 power vs Big Block Olds power | 1FSTLS1 | Big Blocks | 2 | May 30th, 2008 08:42 AM |
| any problems to look for | bulldog | General Discussion | 6 | May 22nd, 2008 05:27 AM |
| problems.... | punishercarr | Eighty-Eight | 1 | March 10th, 2008 02:27 PM |
| problems.... | punishercarr | Transmission | 16 | February 21st, 2008 04:57 PM |
| is anybody else having problems with their power locks or seats??? | BOOMVADA | Bravada | 1 | October 21st, 2006 02:59 PM |
