| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
Electrical Gremlin, PLEASE HELP!
Ok guys, here's the facts as I know them.
I got an engine that won't run. It cranks over but there is no spark in the ignition setting. I get power to the coil in the ON and ACCESSORY settings, but when I crank it the power disappears. Thought it was the HEI wire, bought a new one, no problems there. Got a brand new engine wiring harness and a battery, didn't fix anything. Bought a new ignition solenoid (used the old tumblers) and still the same problem. Any ideas? We're all stumped here. |
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
Hot Rodder at heart Administrator
Do you mean ignition SWITCH or starter SOLENOID? If it was the starter solenoid, then check your ignition switch, the start position is a different set of contact points from the on and accessory positions, it should provide the 12 volts to your coil plus a momentary signal to the starter solenoid to engage the starter motor. If the starter motor is turning but you have no 12 volts WHILE CRANKING the motor then it is probably the switch. If you bought new tumblers for the ignition switch you may still have bad contacts in the switch, I think the tumblers just allow the key to turn in the switch is all.
__________________
Dan '77 Cutlass Supreme '46 2 door "The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB. |
#3 (permalink) | |
Super Moderator
Quote:
__________________
Joe Padavano 64 Jetstar 88 Conv 66 442 L-69 Conv 68 W-30 69 H/O 69 442 70 W-30 72 442 84 Custom Cruiser 86 Caprice wagon (w/307 Olds) |
#4 (permalink) |
If your engine turns over, the starter selenoid is fine. Your little electronic module probably went out in the HEI. I cant remember what its called. its the chip in the bottom that goes out every once in awhile
__________________
69' Cutlass 4 door. Built 455 inside, grandma's grocery getter outside. Best sleeper in disguise.
#5 (permalink) |
Landyacht Club President
You can have the HEI modules checked out at your local auto parts store for free.
__________________
Ferris, my father loves this car more than life itself... Apparently, you don't understand! Ferris, he never drives it! He just rubs it with a diaper! Cameron Frye Ferris Bueller's Day Off 1986 |
#6 (permalink) |
Sorry Joe. 68 Olds 442 with a 70's 455 in it. Upgraded to HEI.
Olds, I bought a new ignition module. The metal part which plugs into the wires in the dash and you can swap the tumblers for the keys, etc. I used the old tumblers, think I should go buy new tumblers and keys? Jeremiah, the starter(new) will engage and turn the motor over, but when I crank, there's no spark in the wires. I have power when the switch is left to snap back into the ON position but it all dies when we crank. Does that sound like a chip? As far as I know the distributor is new but I may be wrong. |
#7 (permalink) |
I'm sorry, I missed your comment about changing the HEI wire.
__________________
#8 (permalink) |
Bah, no biggie. I just hate electrical stuff. I am no good at it.
#9 (permalink) | |
Super Moderator
Quote:
If you get power to the distributor in RUN but not START positions, then someone didn't properly connect the distributor. Keep in mind that the points distributors had two wires going to the coil, one from the START position of the ignition switch that was pure copper and one from the RUN position that had a resistor built into it. BOTH need to be connected for the HEI to work properly in an older car, but the resistance wire needs to be replaced with pure copper also. It sure sounds like the START wire didn't get hooked up. An easy way to test this is to disconnect the power wire from the distributor and run a hot wire directly from the + side of the battery to the BATT terminal on the HEI cap. Be sure to wire a toggle switch in this wire so you can turn the engine off. Turn power on and crank the engine. It should start, or at least you should get spark. Use the toggle switch to turn the engine off. If this works, your problem is the wiring between the ignition switch and the HEI.
__________________
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| electrical schematic | kevinkpk | Electrical | 5 | November 7th, 2007 11:36 AM |
| Electrical | olds75cutlass | Electrical | 4 | September 22nd, 2006 04:14 AM |
| Electrical | BOB W M | Electrical | 1 | April 7th, 2006 07:30 PM |
| Electrical short? | 86in | Electrical | 19 | February 9th, 2005 10:49 AM |
| ELECTRICAL | NV WIDOW | Electrical | 1 | September 1st, 2004 05:34 AM |
