ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Electrical, Interior, and Other > Electrical
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old May 8th, 2008, 09:37 PM   #1 (permalink)
Gaz Hog
Amp idiot light is on
Howdy! My Amp light has been on for some time now, I have yet to have a problem with it. I've got a 69 Delta 88. Alternator does not look to be very old, battery is new, and the voltage regulator is new(er). I got back form a charging system test at Advance Auto: charging fine and doing fine, according to the guy that did the test, but when I looked up at the machine, I noticed the number under the word AMP on it said 4.5. Is that right? When I questioned the fellow, he said, "well, it seems low, but the test shows 13.[whatever] volts." Hmmm.....what should I be seeing and what will eventually happen to me with my car?
Gaz Hog is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old May 9th, 2008, 09:44 AM   #2 (permalink)
Oldsguy
Hot Rodder at heart Administrator
Oldsguy's Avatar
4.5 amps under a charge test? Not sure because don't those machines put different loads on the alternator to simulate real world effects? He SHOULD know however if an alternator was good or not, and not say it "seems" good. What kind of assurance it that? Take is someplace else. A bad alternator could be causing the idiot light to illuminate but it could also be a bad socket on the dash circuit board or even a soft short to ground allowing the lamp to illuminate. Is it lit bright or dim?
__________________
Dan
'77 Cutlass Supreme
'46 2 door
"The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB.
Oldsguy is offline   Reply With Quote
Old May 9th, 2008, 10:06 PM   #3 (permalink)
Gaz Hog
The amp light is kinda dim. never gets as bright as the others...doesn't seem so anyway.
Old May 10th, 2008, 05:37 AM   #4 (permalink)
ozoneblue
ozoneblue's Avatar
Send a message via Yahoo to ozoneblue
A bad diode in the Alt will cause this.But it will still charge Larry
ozoneblue is offline   Reply With Quote
Old May 10th, 2008, 09:11 PM   #5 (permalink)
Gaz Hog
Diodes, according to the test, checked out.
Old May 11th, 2008, 03:47 PM   #6 (permalink)
Oldsguy
Oldsguy's Avatar
Re-check that alternator someplace else, after you know for sure that it is good (or bad and you replaced it) if the lamp is still lit then you have a soft short someplace.
__________________
Dan
'77 Cutlass Supreme
'46 2 door
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
B & M Turbo 400 Trans & Converter <Gary> Parts For Sale 2 January 9th, 2008 03:27 PM
ABS & Trac off light up488 Brakes/Hydraulic Systems 3 January 8th, 2007 06:09 PM
Trunk Light in an 85 Redog Eighty-Eight 1 November 10th, 2006 06:01 AM
ABS,Brake, & Restraint Light on 155thINF Toronado 1 September 12th, 2006 06:03 AM
Light HELP ! Dennis Electrical 1 November 4th, 2004 12:33 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
