ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Electrical, Interior, and Other > Electrical
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old March 24th, 2008, 11:18 PM   #1 (permalink)
projectheaven
projectheaven's Avatar
MSD
I would like to install a msd ignition on my cutlass.My buddy and I were discussing it and have different ideas about what it's exactly for.Can you all tell me exacly what it does?
Thank you!
__________________
____________________
96 Impala ss
96 Buick Rivera(supercharged)
00 Yamaha R1
projectheaven is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old March 24th, 2008, 11:32 PM   #2 (permalink)
88 coupe
Junior Member
88 coupe's Avatar
Quote:
Originally Posted by projectheaven View Post
........ tell me exactly what it does? ........
It impresses the spectators whenever you open your hood.
Norm
__________________
Quote:
Originally Posted by 380 Racer View Post
Quote:
Originally Posted by 88 coupe View Post
None of us can know what we haven't learned yet .....
........ I saw Norm's "helpful" answer and encouragement as a slam ........
88 coupe is offline   Reply With Quote
Old March 25th, 2008, 06:00 AM   #3 (permalink)
Rallye469
Senior Member
On top of impressing spectators...
It's a multiple spark discharge ignition system.
It's designed to completely burn all the fuel in the combustion chamber
by sending out a hotter spark multiple times during the course of each
combustion cycle.
Is your car still running points? Has it been converted to HEI?
Most engines will be just fine with a 74-90 stock GM HEI upgrade.
Factory HEI throws out a helluva spark that takes care of most of
our needs.
Got a picture of your engine bay?
__________________
'70 Rallye 350
'65 F-85
http://www.youtube.com/watch?v=CCw-JmwNGZQ
Rallye469 is offline   Reply With Quote
Old March 25th, 2008, 06:06 AM   #4 (permalink)
Oldsguy
Hot Rodder at heart Administrator
Oldsguy's Avatar
You are talking about an MSD control box right? I has to be used with an after market distributor like one of theirs. Control boxes are used to fine tune the spark delivery; people that race their cars use them to compensate for altitude, air temperature, and other track conditions. Whether the use of a high voltage spark on an older car that is simply driven on the street is beneficial or not is a subject that is still disputed. Some people claim increased fuel economy, others increased horsepower but those claims are rarely backed up by scientific tests. I think I would be safe to say this at least, you won't have to change your points any longer if you put a system like that in, so I guess at the very least you would see easier maintenance in the future.
edit: as usual, my long and slow composition time has ended in a post that seems redundant. Oh well.
__________________
Dan
'77 Cutlass Supreme
'46 2 door
"The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB.
Oldsguy is offline   Reply With Quote
Old March 25th, 2008, 06:13 AM   #5 (permalink)
VWBeamer
Oldsmobile Virgin
Unless you are drag racing and need 2-3 step rev control, and/or running N2O/Boost and need spark retard, there is no advantage to MSD over HEI IMHO.
If fact HEI is often adapted for use on other engines. It's simpler, easier to install and often cheaper.
If are planning on drag racing, I would run the digtal mallery 6A, it has boost retard and a 2 step built in for about 40 bucks more than an analog MSD. I run one on my car and never had a problem. I can also change rev limits with buttons, and not have to but pills like the old analog MSDs. Just my .02
VWBeamer is offline   Reply With Quote
Old March 25th, 2008, 07:35 AM   #6 (permalink)
joe_padavano
Super Moderator
There are different types of MSD units. The basic box just provides multiple spark firings for each compression stroke. The theory is that if the first spark doesn't completely ignite the mixture, the second or third will. I'm on the fence here. Norm is correct - a properly tuned ignition system and correct fuel delivery shouldn't require this crutch. On the other hand, I've used an MSD6 on a 455 with nitrous and it did seem to help on the track (note to Norm - the MSD box was hidden under the dash and didn't help with that spectator impressing function. Clearly I made a mistake there... ).
The newer MSD boxes have a number of additional functions that are beneficial. You can, for example, use an MSD unit to provide complete control over your advance curve. This may require additional sensors, but the ability to dial in an advance curve from the driver's seat has some advantages. Other available functions are rev limiter and multi-step control for specific racing classes.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
joe_padavano is offline   Reply With Quote
Old March 25th, 2008, 01:15 PM   #7 (permalink)
The_Jeremiah
Norm
ROFL, well spoken by norm
__________________
69' Cutlass 4 door. Built 455 inside, grandma's grocery getter outside. Best sleeper in disguise.
The_Jeremiah is offline   Reply With Quote
Old March 25th, 2008, 02:34 PM   #8 (permalink)
projectheaven
Heres some pics of the engine bay.I have a HEI distributor.From what you guys are telling meI think I'll leave the msd alone for now.
__________________
96 Impala ss
00 Yamaha R1
Old March 26th, 2008, 06:51 AM   #9 (permalink)
Oldsguy
Oldsguy's Avatar
My friend,
If you spend a saturday cleaning and detailing that engine compartment it would be so much better and do justice to such a nice looking car. Seriously, a bag of shop rags, a roll of paper towels, a good cleaner like simple green, some windex, a small brush, some elbow grease, and you have a nice sparkling engine bay that makes that small block POP! You already have enough chrome, offset it by getting that black on the fender wells and firewall to shine. Hoses too.
__________________
Dan
'77 Cutlass Supreme
'46 2 door
Old March 26th, 2008, 07:19 PM   #10 (permalink)
projectheaven
Oldsguy you must be reading my mind because that's exactly what I was going to do this weekend but I didn't know how to go about it. So you said simple green and elbow grease huh? I'll give a try and post pics.
Thank you
__________________
96 Impala ss
00 Yamaha R1
Old March 26th, 2008, 07:32 PM   #11 (permalink)
The_Jeremiah
It will look a lot like mine : )
__________________
Old March 27th, 2008, 06:07 AM   #12 (permalink)
Oldsguy
Oldsguy's Avatar
Well, various cleaners, simple green is one of my favorites for plastic and rubber. It is mild enough that it doesn't damage parts, sometimes requires more than one application. Windex on chrome after you cleaned everything up leaves no streaks. If your chrome is pitted some you will need a polishing paste (lots of brands out there). If you have a shop vacuum cleaner used if first with a dry old toothbrush or similar tool to knock loose the big chunks of dirt and junk and then suck it up with the vacuum. A small brass bristle brush shaped like a toothbrush (can be purchased at the hardware store) can be used to get old burnt paint off the heads near the exhaust port and also to clean off rust on the exhaust manifolds but only do that if you intend to re-paint the same day. Then, if you do, mask everything else well. A few small rattle cans of paint should do for touch up purposes, won't last forever but will surely last a while, I would re-paint that alternator bracket satin black, I think that was more original looking and contrasts with the gold engine and chrome accessories well. Any way, getting carried away here. Have fun.
__________________
Dan
'77 Cutlass Supreme
'46 2 door
Old March 27th, 2008, 06:20 AM   #13 (permalink)
Olds64
Landyacht Club President
If you are running HEI you should be fine. Only spend the money if you don't have anything else to do.
BTW, that engine bay does look nice. Show us a picture once you clean it up. You might also want to take the air plenum apart and remove the AC parts from the car since you don't have the compressor on it anymore. I did that with my 64 and it looks a million times better. You can always save the hoses, condesor, accumulator, etc. if you want to put AC back on the car in the future.
__________________
Ferris, my father loves this car more than life itself... Apparently, you don't understand! Ferris, he never drives it! He just rubs it with a diaper!
Cameron Frye Ferris Bueller's Day Off 1986
Olds64 is offline   Reply With Quote
Old March 27th, 2008, 06:43 AM   #14 (permalink)
joe_padavano
Super Moderator
The only problem with removing the A/C box is that you need to remove the passenger side fender (or at a minimum the inner fender) to get to all the nuts. You may also want to consider finding a non-A/C alternator bracket to put the alternator on the passenger side. This will help balance the side load on the water pump and can extend water pump bearing life.
I've found that pre-cleaner solvent (available at auto paint stores) is one of the best things for cleaning wiring and spark plug cables. The pre-cleaner won't damage plastic or rubber and cuts grease very quickly. It MAY remove some date code ink, so be sure to test it first if you care about that.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
Old March 27th, 2008, 09:13 PM   #15 (permalink)
projectheaven
Wow! Those were all great suggestions.This weekend is the good guys car show in the bay area so after I finish looking at other cars in amazement I will definitely take the time to clean my engine bay. THANK YOU!
__________________
96 Impala ss
00 Yamaha R1
Old April 6th, 2008, 08:10 PM   #16 (permalink)
projectheaven
engine bay
Hello all. I took the advice from you fellow oldsmobile guys and cleaned up my engine bay a little.How does it look?
OLD
NEW
__________________
96 Impala ss
00 Yamaha R1
Old April 7th, 2008, 06:59 AM   #17 (permalink)
Oldsguy
Oldsguy's Avatar
That looks much better. The work was worth it, yes?
__________________
Dan
'77 Cutlass Supreme
'46 2 door
Old April 7th, 2008, 08:09 PM   #18 (permalink)
projectheaven
It definitely was. Thanks for the little push!!!
__________________
96 Impala ss
00 Yamaha R1
Old April 9th, 2008, 05:48 PM   #19 (permalink)
68conv455
Is that a future cutlass owner/driver checking out the engine bay detail from a warm blanket? Keep the keys in a safe place.
68conv455 is offline   Reply With Quote
Old April 9th, 2008, 05:56 PM   #20 (permalink)
Redog
Alero Chapter Secretary
Redog's Avatar
Gotta clean my engine bay now
I just bought a new cap, rotor, advance, and coil. All stock and the car runs better now.
The weights and springs on the otherhand. If I can get my hands on a new base, I can rebuild that and swap the rest
__________________
Me
2000 Alero running 14's
2005 Nissan Altima (her's)
1967 Olds 330 motor sitting on a stand
1985 Delta 88 w/1968 350 rocket ( MURDERED )
Redog is offline   Reply With Quote
Old April 9th, 2008, 09:33 PM   #21 (permalink)
projectheaven
Yes, that is a future cutlass owner.My other kids like my 96 impala ss in the background but this one is a olds man.
__________________
96 Impala ss
00 Yamaha R1
Old April 10th, 2008, 11:20 AM   #22 (permalink)
Olds64
Lookin' good!
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
MSD Ready to Run HEI Oldsproject Electrical 2 July 3rd, 2007 10:53 AM
MSD ignition in an 85 Delta 88 Redog Electrical 3 March 4th, 2007 01:28 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
