Fuse Panel Diagram in Service Manual?
Old September 29th, 2012, 06:12 AM
jpc647's Avatar
IS there a fuse layout in the service manual for 1972? A couple lights in the passenger compartment don't work, and I'm wondering If I have a bad fuse. I took them out and looked at them, and I can't find a single one that's burnt out.
If I had the layout I could replace 1 or 2, and know if it's a fuse or something bigger. Went through the Chassis Electrical section on the service manual, can't find one. Only thing I could find was a list of the circuits and what they are for, but not which circuits are where in the fuse panel.
jpc647 is offline
Old September 29th, 2012, 06:22 AM
jpc647's Avatar
Let me rephrase here, all the supposed designations are no longer on my fuse block. Does anyone have a 72 Cutlass and able to take / post up a decent resolution picture of their fuse block, so I can match up to mine, and check them?
I've got a few things not working, like my cigarette lighter socket, my directional arrows on the dash, and the temp/oil/brake lights on the left gauge. But other things on those circuits are working... hmm.
jpc647 is offline
Old September 29th, 2012, 08:47 AM
Lansing built
1970cs's Avatar
1972 service manual
Here you go!
join wildaboutcars, and free to join and access!
http://wildaboutcarsonline.com/membe...ection_12A.pdf
pg 12-5 or pdf#5
Pat
1970cs is offline
Old September 29th, 2012, 08:56 AM
Sounds like you're looking for this diagram: (its from the Assembly Manual, not the CSM). BTW, I'd start with checking the bulbs to see if they are burnt out or have corroded contacts.
Allan R is offline
Old October 1st, 2012, 08:54 AM
jpc647's Avatar
Pat,
Wow i flipped right past it in the manual, was expecting a full page diagram I guess.
I've swapped the bulbs around to test, and its definitely the cluster, or the circuits for the oil, temp, and brake lights. I determined last night there is no juice going out to the senders, the oil pressure one, or the temperature one. So it might be grounding out somewhere else. I traced the harness around the passenger side of the motor and around the back where it ties into the harness. Not sure if it goes directly to the fuse panel or if it goes up to the junction box on the firewall. Need to peel the harness back tonight/tomorrow to find out.
jpc647 is offline
Old October 2nd, 2012, 11:33 AM
Have you also checked the fuse box to see if the holders aren't corroded? If they are no current will flow. I remember you saying
so possibly this panel has seen better days? BTW, where are you located?
Allan R is offline
Oldscutty72
December 28th, 2015 01:56 PM
Boldsmobile
December 13th, 2015 07:16 PM
White_Knuckles
August 23rd, 2012 09:08 PM
Del70
July 6th, 2011 03:46 AM
patmills
December 11th, 2010 07:54 PM
Quick Reply: Fuse Panel Diagram in Service Manual?
