1967 Cutlass Fuse Panel Diagram?
Old August 22nd, 2012, 08:08 PM
White_Knuckles's Avatar
Still in my first month of ownership and sorting out electrical gremlins. It would be helpful if someone may have a scan or image of the fuse-block layout and fuse rating diagram.
So far I've recovered dash lights the gas gauge, idiot lamps and other failed circuits. Seems someone broke off the bottom of the fuse block where the fuse labeling is missing. I've found the brake fuse (20A) socket was beyond repair so I relocated the brake lamp load wire to the lower left most (20A) fuse. I used a tap collar slipped over the existing fuse. Problem is, I'm not sure what other circuit the fuse is also managing? The block lettering is gone!
May have to ditch the block and swap in a modern style. The fuse copper clamps seem to be too crusty to trust 'em.
White_Knuckles is offline
Old August 22nd, 2012, 08:55 PM
You do have the Chassis Service Manual, right?
Page 12-8.
MDchanic is offline
Old August 23rd, 2012, 08:57 PM
Thanks MD. Um, that would be no on having a chassis manual. Should you have a source and title for one, please reveal it!
Looks like I tapped a normally hot circuit (Dome) for the brake lights. The additional load should be fine.
Old August 23rd, 2012, 09:08 PM
chrisneu68olds's Avatar
Wild About Cars
Go to http://wildaboutcarsonline.com/index.html and sign up for free. They have all the manuals you need there. The cost? NOTHING! Just download and read at your leisure.
chrisneu68olds is offline
rwalker
March 26th, 2020 05:45 PM
Oldscutty72
December 28th, 2015 01:56 PM
jpc647
October 2nd, 2012 11:33 AM
matchek
August 19th, 2012 11:17 AM
wantacutlass
June 17th, 2010 04:09 PM
Quick Reply: 1967 Cutlass Fuse Panel Diagram?
