Go Back   ClassicOldsmobile.com > Repair & Restoration > Electrical
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 10-11-2007, 05:30 PM   #1 (permalink)
Pghstarsky
Senior Member
Send a message via AIM to Pghstarsky
Turnsignal problems.
Hi, I have a 72 Cutlass and I am having some difficulty with my turn signals, the problem is that they don't work at all. I replaced both flashers and just upgraded my fuse block and the signals still don't work. Everything else works with the exception of the back up lights and I just don't know what to do with these turn signals. So, I'm really hoping that one of you guys will be able to help me out before I replace the turn signal switch. Thanks,
Sam
Pghstarsky is offline   Reply With Quote
Sponsored Links
To remove this ad, register today!
Old 10-13-2007, 08:28 AM   #2 (permalink)
ozoneblue
Senior Member
Send a message via Yahoo to ozoneblue
Do you have hazard Flashers & stop lights ? is the problem just on back or both, If just in back check the aluminum harness under driver side carpet to trunk.Often rots out
ozoneblue is offline   Reply With Quote
Old 10-13-2007, 06:17 PM   #3 (permalink)
Pghstarsky
Senior Member
I know that I have stop lights, they work. I didn't check if the hazards work. I'll do that tomorrow. Thanks
Old 10-14-2007, 07:28 AM   #4 (permalink)
Olds64
Landyacht Club President
If you have rear tail lights and brake lights but no turn signals then check the fuse for your turn signal circuit. If this doesn't work then check the turn signal switch. I recently had a similar problem with my car and it turned out that the fuse for my turn signals went bad when one of my bulbs had a short. I had to replace the bulbs and fuse but now everything is working fine.
Olds64 is offline   Reply With Quote
Old 10-15-2007, 04:44 AM   #5 (permalink)
Pghstarsky
Senior Member
Well, I guess it's the switch then, cause I have hazard lights and all of the bulbs work, except the back up lights...which makes me think I might have wired something wrong since the back ups and turnsignals are on the same fuse. Oh, and is there a difference between the turnsignal flasher and the hazard flasher. Cause I put a turnsignal flasher in for the hazard and now they blink super fast. Thanks,
Sam
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Problems with gauges sama87 Electrical 3 11-04-2007 09:55 PM
alternator problems again 2 door cut Cutlass 7 06-10-2007 02:16 PM
wire problems D Appeldorn Electrical 0 04-17-2007 01:55 PM
455 problems mad_mike06 Big Blocks 0 12-04-2006 01:22 AM
Carb Problems DonFrost Ninety-Eight 12 07-10-2006 03:50 AM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
