Go Back   ClassicOldsmobile.com > Repair & Restoration > Electrical
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 08-27-2007, 08:39 PM   #1 (permalink)
Chumley
Senior Member
72 Tail light wiring
What is the correct wiring for the tail lights? I'm replacing old rusted sockets and am confused on the wiring. I have 2 dark green and 2 brown wires going to each side. (one pair for each lamp) HOWEVER, the left side has some extra wires tied in to the green and brown. There are 2 red and 2 black wires as I recall. The wiring schematic does not indicate these wires, and unless I'm reading the diagram wrong, it shows a yellow wire going into the left side lamps(originating from the turn signal switch) along with the brown wire. Also on the left side lamp sockets, there is a flattened black ground wire that comes from the rear of the socket and slips onto a prong on the lamp side of the socket. These sockets are toast, and I need tp replace them. Can I just connect the dark green and brown to the left side like the right side is connected and scrap these other extra wires? I think somebody MickeyMoused this years ago, as well as some other things on the car. Also, does the running light lamp go on the top or the bottom? Are both lamps supposed to be on at once? When I was testing them, one lamp was bright and one was dim when the lights were turned on. As you can see, I'm somewhat confused. Any input appreciated. Thanks, Chumley
Chumley is offline   Reply With Quote
Old 08-28-2007, 03:41 AM   #2 (permalink)
ozoneblue
Senior Member
Send a message via Yahoo to ozoneblue
Yellow wire is LH turn & stop, Green RH & brown tail The other lt grn is back up & black is ground
ozoneblue is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
tail light lens question shaks 442 clone Other 7 08-22-2007 04:04 PM
Tail light housings Musman70 Chassis/Body/Frame 3 05-23-2007 04:59 PM
tail light wiring for 62 88 dynamic62 Parts Wanted 2 03-05-2007 04:43 PM
Tail light trouble Lilly Electrical 1 10-24-2006 05:06 AM
1976 delta 88 rear left tail light henry j Cars Wanted 0 06-14-2003 02:38 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
