How to wire ammeter with a 1 wire alternator?
Old April 10th, 2011, 12:17 PM
Joel's Avatar
Hi, if I put a 1 wire alternator in my 67 442, how can I make it activate the factory amp guage? Thanks, Joel
Joel is offline
Old April 10th, 2011, 03:56 PM
Why do you want to use a one-wire alternator? If you want an internally regulated alternator, simply get a 12SI and wire it like this:
joe_padavano is offline
Old April 10th, 2011, 05:15 PM
Joel's Avatar
Thanks for the reply. Joe.
THe reason that I am cosidering using a one wire is that the car is comming out of 24 years of storage, and the regulator looks corroded, plus I have a new one wire alternator that I got in a barter deal. If it won't work with the amp guage, that makes a difference.
I'm driving the car on Hot Rod's Power Tour in June, and I want it to be reliable.
So what do you think, should I give up on the one wire deal, or can I make it work?
Joel is offline
Old April 10th, 2011, 05:21 PM
2blu442's Avatar
Joel, this has been discussed before in previous threads. You can use the search option to find them, but you can read through this one for a little more background. It sounds to me like the one wire alternator is not the way to go. John
https://classicoldsmobile.com/forums...tml#post255425
2blu442 is offline
Old April 11th, 2011, 11:17 PM
Lalo442's Avatar
Also you might want to check the new one-wire alternator you have if it is a 10 or 12Si case look for a rubber plug where the factory plug goes if you pull it out most aftermarket one wires already have the internal regulators then all you need is to pick up a plug at your local autoparts or a spare from a newer car and splice it in per Joe's diagram ,,,,
Lalo442 is offline
Old April 12th, 2011, 02:58 AM
... the car is comming out of 24 years of storage, and the regulator looks corroded...
You can't tell how good a regulator is by how it looks.
Kinds like my cooking .
MDchanic is offline
442mark
September 30th, 2017 01:06 PM
starfire
August 19th, 2013 05:56 AM
ElmoIsBold
April 8th, 2012 11:21 AM
yeahbuddy
December 1st, 2011 10:29 PM
Bobac455
April 11th, 2010 09:35 AM
Quick Reply: How to wire ammeter with a 1 wire alternator?
