67 cutlass resistor - ClassicOldsmobile.com
LinkBack Thread Tools Search this Thread
Old February 12th, 2011, 01:24 AM   #1
67 cutlass resistor
Could somebody help me if at all possible. I have a 67 cutlass and I'm in need of a resistor for the blower motor. I have attached a picture of the one I have, but I'm in need of a new one because this one doesn't work anymore. I've tried eveywhere to locate one, but the prongs are not in the right position. Anyone have an idea where I could get one like this.
Kt 74 is offline   Reply With Quote
Old February 12th, 2011, 05:39 AM   #2
Beob's Avatar
Are you 100% sure its bad, whats the problem? Do you have AC? Fusick sells new ones for non AC.
Beob is offline   Reply With Quote
Old February 12th, 2011, 06:26 AM   #3
Registered
Bluevista's Avatar
I looked at the service manual over at Wild About Cars and it shows a three prong resistor?
The wiring schematic shows three wires to the resistor from the control too, brown-blue-green and the brown pigtails out and goes to the blower motor.
This does mount to the top of the heater case inside the car?
It looks like the A/C resistor type is mounted on the outside and is shaped differently so it isn't that.
The Canadian online parts catalog shows the resistor as part #9793206 for all 65-67, I did a search and some Corvette place has them and they're the three prong type.
Maybe they made a change during the model year or somebody coudn't find the right one and used that?
If that extra lug is common with one of the others that could be possible, does that single lug wire go to the blower motor?
Otherwise...got me?
Bluevista is offline   Reply With Quote
Old February 12th, 2011, 07:05 AM   #4
Far as I know heat-only (which is shown in the main diagram in the manual) is 3-prong, and A/C (which is only shown in a separate diagram in the A/C section of the manual) is 4-prong, but '67 is one year earlier than I'm used to, so it could be different.
And, as Bob said, make sure it's bad. Failure mode is generally a broken or melted coil - if the coils are intact, the unit should be good, and it's probably a dirty connection.
MDchanic is online now   Reply With Quote
Old February 12th, 2011, 10:37 PM   #5
This is for an ac car. The single prong goes to the blower motor. The reason why I say it is bad is because one of the resistors is broke. I ordered one from the parts place inc. and it does have the four prongs but they do not align up the same. The prongs go sideways instead of long ways.
Old February 13th, 2011, 06:14 AM   #6
Your best bets may be either the junkyard, or to post a couple more pics in the Wanted section and see if anyone here has one.
Old February 21st, 2011, 08:35 PM   #7
I might have a good one from a 66 cutlass. Will it work??? PM me.
Nor Cal Andy is offline   Reply With Quote
Old February 21st, 2011, 09:01 PM   #8
OLDSmobility's Avatar
Here's a couple comparison pictures I took last fall when I was getting started converting my A/C car to heater only. The A/C resistor is on the left, the one for a standard heater is on the right.
(click to enlarge)
I have no need for this A/C resistor...it's yours for shipping. (I think it's still sitting out on my workbench.)
OLDSmobility is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
blower resistor connector for AC cutlass crank shaft Parts Wanted 27 November 5th, 2013 04:22 AM
73 Cutlass with bad resistor: Help. Mac1973 General Discussion 5 July 16th, 2013 11:17 AM
WANTED 72 Cutlass blower motor & resistor MJAKS462 Parts Wanted 4 July 22nd, 2010 04:44 PM
72 cutlass blower resistor mmcilroy Parts Wanted 13 January 25th, 2010 05:03 AM
external coil resistor david adelberg Cutlass 2 June 2nd, 2008 07:10 PM
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content Copyright 2008 by Internet Brands, Inc.
