Go Back   ClassicOldsmobile.com > Repair & Restoration > Electrical
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 05-23-2007, 12:16 PM   #1 (permalink)
1973_442
Junior Member
350 not starting
hello
i have a 1973 442 with a 350cid. when i try to start the car the starter wont kick in, ive connected the leads on the solenoid with a jumper, and it spun up so its getting power, the battery is fine, so is the ignition switch. the headlights and accesories all work, as well. i was thinking maybe the neutral safety switch is fried, but i was wondering if anybody here had any other ideas?
1973_442 is offline   Reply With Quote
Sponsored Links
To remove this ad, register today!
Old 05-23-2007, 01:33 PM   #2 (permalink)
joe_padavano
Quote:
Originally Posted by 1973_442 View Post
hello
When you say the starter doesn't kick in, do you mean it doesn't turn at all or that it spins but doesn't engage the flywheel? If the latter, it could be the starter drive or the solenoid. If the former, it could be the neutral switch. Disconnect the purple wire from the solenoid and check the voltage to ground when a helper holds the key in the START position. If you get 12 volts, the neutral switch and ignition switch are likely good. Next pull the connector with the two purple wires off the neutral switch at the base of the steering column and jump across the terminals in the connector. Now try to start the car. If it works, the switch is bad.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
joe_padavano is offline   Reply With Quote
Old 06-13-2007, 09:22 AM   #3 (permalink)
jk121
Junior Member
sounds like the solinoid to me
jk121 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
