| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
Junior Member
WHAT IS THAT BLACK RELAY LOOKING THING WITH THE BIG PURPLE WIRE GOING INTO IT.RIGHT BETWEEN THE FUSE BLOCK AND THE DIMMER SWITCH.IT IS A 74 CUTLASS SUPREME (442).THE REMOVEABLE PART IS NUMBERED ON EACH OF THE FOUR PRONGS?????????
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
Hot Rodder at heart Administrator
NVWindow, on older cars like mine, purple is usually for primary (12 volts), or sometimes pink. If it goas to your dimmer switch, I would guess it is your unswitched 12 volts but I am not sure. If you say big meaning larger guage than the others this would lead me to think that even more so. Can you get a voltmeter to check that? Or do you have a friend that can help you? That would be best. What is your trouble?
supreme3.4dohc, what kind of question do you have about the alternator?
__________________
Dan '77 Cutlass Supreme '46 2 door "The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB. |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1970 F85 W31 | mono-plane | Cars For Sale | 122 | November 15th, 2009 07:12 AM |
| cowl plate | donald tolbert | Toronado | 1 | January 5th, 2007 08:48 AM |
| 55 Olds 88 Coupe | troberts6 | Electrical | 3 | December 13th, 2006 03:44 PM |
| '54 Holiday coupe | Fishydoo | Chassis/Body/Frame | 2 | October 20th, 2006 06:28 PM |
