| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Dealer Listings |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
Junior Member
Windshield washer keeps on keeping on!
Hi Guys ( & Gals),
On my 70 Cutlass Supreme, when I turn on the wipers (without pushing the washer button) the washer pumps and pumps until I shut them off, any clues. Thanks, Rich |
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
Hot Rodder at heart Administrator
GM uses a mechanical cam that runs off the wiper motor shaft, this cam drives the pump and it is activated by a switch located on the wiper motor. Look at the wiper motor (mounted on the firewall, driver side) it should have a black plastic housing which covers it and there should be a wiring connector facing the front of the car, this connector should have two wiring harnesses attached, one is for the motor, the other is for the pump, I can't remember which one is which. Inspect both for any signs of corrosion, clean them up with some alcohol and an old toothbrush or something if you find any corrosion. This might help. Also, most auto parts stores sell a repair kit for the wiper motor for GM as almost all of them were the same, again, I am not sure how much or exactly what is in the kit. I have done it before but it was a long time ago. Good luck and welcome to our site!
__________________
Dan '77 Cutlass Supreme '46 2 door "The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB. |
| Thread Tools | |
| Display Modes | |
