ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Electrical, Interior, and Other > Electrical
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old September 5th, 2009, 04:42 PM   #1 (permalink)
nelsontj
Brake Indicator Light Not Working
1970 Olds 442 brake indicator is not working when I press down the parking brake and/or first turn the ignition switch. I tested the bulb (even replaced it with a new one), bulb holder and fuse. They all passed the continuity test. I haven't had any recent work on the car. It was working before today. Any ideas or thoughts?
nelsontj is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old September 5th, 2009, 05:42 PM   #2 (permalink)
joe_padavano
Super Moderator
Quote:
With the key in the RUN position, temporarily remove the wire from the brake distribution block on the frame rail below the master cylinder and ground the wire. The light should come on. If not, and if you are certain the bulb is good, then you have a wiring problem. Either the pin on the printed circuit board on the back of the gauge pack is loose or the wire is broken in the harness.
If the light does come on when tested as above, then the problem is likely the switch on top of the e-brake pedal assembly.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
joe_padavano is offline   Reply With Quote
Old September 9th, 2009, 04:09 PM   #3 (permalink)
nelsontj
Joe (or anyone else),
I found it is a loose connection at the harness to the gauge. I am having trouble getting the wire terminal out of the harness using a paper clip. Any tips, or help, would be greatly appreciated.
Old September 9th, 2009, 07:18 PM   #4 (permalink)
joe_padavano
Super Moderator
Sometimes inserting the paper clip will push the lock tang on the terminal into the connector housing, preventing it from coming out. Try pushing on the wire so you preload the terminal forward in the connector housing THEN while holding it there, insert the paper clip to depress the tang. That usually releases it for me.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
Old September 9th, 2009, 07:28 PM   #5 (permalink)
Lady72nRob71
Lady72nRob71's Avatar
Is it a small paperclip? That or a VERY thin nail will help release the wire. Big paperclips are too fat.
Look in the slot with a flashlight to make sure you are pushing in on the right tab. Whatever you do, do not pull on the wire and push on the nail / clip at the same time. Push nail in first, then pop out wire.
After it is out, bent out the little tab again to make sure the wire stays in.
__________________
-Rob Young
1972 Cutlass Supreme Convertible (442 clone) -"Lady" (My mistress...)
http://www.flickr.com/photos/robsalbum/sets/
1986 Cutlass Supreme Coupe - "Pristine"
1978 Ford (Old Faithful) a.k.a. "the Tramp"
1997 Cadillac STS (for sale - too many cars!)
1999 Harley Davidson Sportster - "the Freedom Machine"
Lady72nRob71 is offline   Reply With Quote
Old September 9th, 2009, 07:30 PM   #6 (permalink)
nelsontj
Thanks for your help Joe! You are an invaluable source of information on Oldsmobiles.
Old September 9th, 2009, 07:31 PM   #7 (permalink)
nelsontj
And you are too Rob. Thanks again everyone!
Old September 15th, 2009, 06:16 PM   #8 (permalink)
nelsontj
Need help still! I tried paper clip, small nail and even jeweler's screwdrivers and I cannot get the wire out of the connector harness. Is the hole (left side as you are looking at the connector head-on) on the side of each terminal female hole where I stick the paper clip or nail to press down the locking tang? This is all completely new to me. I've never have done this operation. Thank you.
Old September 16th, 2009, 04:01 AM   #9 (permalink)
Yellowstatue
Certified Fanatic
Yellowstatue's Avatar
Tritrinitoluene
__________________
'57 S88 HC et al; '68 442 M20; '68 442 M21; '68 W30; '68 Vista et al; '80 -'84 Regency et al; '96,'98.'99 Aurora..Ignition ON
Yellowstatue is offline   Reply With Quote
Old September 16th, 2009, 06:22 AM   #10 (permalink)
Lady72nRob71
There would be a small hole (or slot) in the gauge-side of the connector.
Push wire in, insert tool into hole and push it in firmly (usually you can feel it 'pop' a little), and pull wire out.
Can you post a picture of the front (gauge side) of your connector? I could then confirm you are using the right holes. I cannot remember what mine look like (that was the only piece I did not take pictures of...)
__________________
-Rob Young
Old September 16th, 2009, 06:31 PM   #11 (permalink)
nelsontj
Rob,
One of our fleet mechanics, from where I work, loaned me some terminal picks today. One was just the right size and it worked like a charm. It is a good example of "the right tool for the job" kind of thing. All that is left is putting in the new sending units. There is an issue of the oil and temp needles pegging when the ignition is first turned on, but I think that issue was addressed in one of the recent issues of OCA's JWO. If you know the fix, let me know. Thanks again for your postings.
Old September 17th, 2009, 06:53 AM   #12 (permalink)
Lady72nRob71
So why the replacement of the sending units? Are you changing to a Rally Pac? I thought this was just for a brake warning light issue, but I could have missed something...
If changing to gauges, replacing the sending units will help. There will be one small green wire to disconnect from the ignition switch to disable the temp light bulb test feature to prevent pegging of the temp gauge when cranking the engine.
Right tool for the right job is right! I have one odd-sized skinny long nail i set aside just for terminal releasing!
__________________
-Rob Young
Old September 19th, 2009, 05:24 PM   #13 (permalink)
nelsontj
I guess I did confuse everyone. What started with the brake indicator light problem turned into changing the warning light gauges to a rallye pac gauge unit I had sitting around. I figured since I had everything apart I may as well install the gauge system. The temperature gauge "pegging" has me curious. I have a 1996 Buick Roadmaster station wagon and a 1992 Chevrolet Lumina Euro, which both have temperature gauges that "peg." I have never had any problems with the needles on the gauges and they have been started many, many more times than my 1970 Oldsmobile 442 has. Why would the needle on the latter be any more sensitive than the needles on the former?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Brake Light issue dan68toro Electrical 4 August 12th, 2008 12:27 PM
'64 Olds Brake Lights not working black betty Electrical 3 December 21st, 2007 01:13 AM
Brake light still on ztim Brakes/Hydraulic Systems 21 August 13th, 2007 10:15 AM
'63 88 turn signal indicator light Big Joe P Electrical 1 May 23rd, 2007 05:29 AM
76 olds ninety eight-turn indicator light housing jeff sanford Electrical 1 July 23rd, 2006 05:58 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
