ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Electrical, Interior, and Other > Electrical
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old October 29th, 2006, 02:50 PM   #1 (permalink)
clintcooper74
Junior Member
1995 olds cutlass problem
I'm trying to work on my girlfriend's 1995 Olds Cutlass Supreme and make it safe for her and the kids to travel around in. I replaced brake pads, rotors, and front calipers. The brakes work fine, and untill yesterday, the tail lights worked fine also. The car is a 95 cutlass, 4 door, 3.1 liter, with cruise control. I checked the stop light fuse, its not blown, and i replaced the stop light switch(by the brake pedal). The taillights come on regularly when the headlights are turned on. The 4-way flashers/hazzard lights work fine. The lights do not get brighter when the brake pedal is depressed, and the light in the back window doesnt work either. The front blinkers work fine, but nothing in the rear. I'm lost. I checked the fuse, and replaced the stoplight switch. Could the cruise control switch(located right above the stoplight switch) be the problem? Is this car equipped with a master cylinder switch? Any info/ideas would be greatly appreciated. We don't really have the money to take it to a shop, and can't afford any tickets, so if anyone has any hints we would be grateful.
Thanks.
clintcooper74 is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old October 30th, 2006, 07:43 AM   #2 (permalink)
ozoneblue
ozoneblue's Avatar
Send a message via Yahoo to ozoneblue
Does the switch have powercoming to it& leaving when pedal is pushed ? .If so chech the plug for the T/S switch I have seen this connection burnt many times,if power gets there & leaves check the connection arount the trunk area .Prosses of elimination procedure would cost you $$ per hour
ozoneblue is offline   Reply With Quote
Old October 30th, 2006, 07:57 AM   #3 (permalink)
Oldsguy
Hot Rodder at heart Administrator
Oldsguy's Avatar
If the rear lamps get brighter when you activate the 4-way hazard switch, then the lamps and the wiring from the front of the car to the back is good. You must have a problem in a switch or a junction someplace under the hood. You really need to get a maintenance manual with a wiring diagram to be sure, unless someone has tackled and solved this one before. Good luck.
__________________
Dan
'77 Cutlass Supreme
'46 2 door
"The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB.
Oldsguy is offline   Reply With Quote
Old November 11th, 2006, 08:42 AM   #4 (permalink)
clintcooper74
Junior Member
Thanks to everyone for the help. Well it took awhile, but finally I figured out it was the turn signal switch. Not a very easy fix for someone who hasnt ever done this before, trust me. If anyone ever has to do this on a similar car to mine, i strongly suggest buying or borrowing a tool to put the steering wheel lock mechanism back in place, the spring that holds everything in place has so much force that its about impossible to push down without a tool. Also, be sure to disconnect the battery before you start working on this project because of the airbag. Oh yea, I called a mechanic and asked how much to replace the t/s switch and I was quoted $360. The switch only cost me $54, and the tool to put the wheel back on was $14, a do it yourself savings of about $300. Thanks alot everyone.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Fulton Sunvisor for a 56 Super 88 56TuTone88 Chassis/Body/Frame 4 December 28th, 2006 03:59 PM
65 Ninety Eight muttmeg Ninety-Eight 2 December 15th, 2006 11:08 PM
75 olds conv. shaunr Eighty-Eight 0 November 18th, 2006 05:47 PM
cutlass doesnt go fast 2 door cut Cutlass 0 September 5th, 2006 07:29 PM
Oldsmobile Links PetChemMan Other 0 September 5th, 2006 07:40 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
