| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
Cutlass driver in Germany
69 Cutlass S, breaklight wont work, electrical problem
I recently got a 69 Cutlass S conv. and I checked the lights after people told me my passenger side tail breaklight would not work. I changed the bulb and checked for ground, no light. But the turn light will work.
Driver side tail light is good both the breaklight and the turnlight, but if I push the hazzard button both front turn lights work and none of the turn light in the rear. I checked the break switchcable, seems to be okay, got power on the cable when I push the pedal. How to hunt the problem down. Break and turn modus use the same wire, so why would break contact not come? Please help, thank you. craftsmen22 |
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
Brake lights
The brake lights & turn signals are all seperated at the T/S switch take off steerng wheel & try spraying some electrial cleaner on switch while operating it
#3 (permalink) |
Brake light
Thanks for the reply. I did take down the steering wheel and I found a spring which came out of the socket. I put it back in and the lights work fine.
Once again, Thank you. craftsmen22 |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Cutlass Body Teardown on my 92 | mrwilde | Cutlass | 14 | May 22nd, 2007 02:04 PM |
| cowl plate | donald tolbert | Toronado | 1 | January 5th, 2007 08:48 AM |
