ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Electrical, Interior, and Other > Electrical
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old July 16th, 2009, 07:25 PM   #1 (permalink)
gearhead1218
gearhead1218's Avatar
Fuseable link replacement with fuse
Traced my wiring and realized the link off the horn relay is cooked.
That line feeds a number of cicuits.
Anyone know what size fuse I should use to eliminate the link?????
I just found a nice 30 amp holder with a fuse in my parts, and was wondering if that's big enough or too big.
__________________
John Castelli
1970 Oldsmobile Cutlass Supreme
1969 Mercury Cougar Convertible
2003 Chevy Siverado
2003 Chevy Trailblazer
2007 Chevy Impala
gearhead1218 is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old July 19th, 2009, 07:02 AM   #2 (permalink)
gearhead1218
Anyone ???????
__________________
John Castelli
2003 Chevy Siverado
2007 Chevy Impala
Old July 19th, 2009, 09:43 AM   #3 (permalink)
Lady72nRob71
Lady72nRob71's Avatar
The fusible link powers everything that comes right off the fuse box.
The 72 Cutlass uses a short section of 16 gauge wire as a fusible link.
How long is yours? I do not recommend a 30A fuse, even a slow-blow. Current through there is probably more like 40A with all accy's on. Check with some of the local parts stores to see if they carry fusible links. It will need to be spliced in and securely soldered in place.
Hope this helps some...
__________________
-Rob Young
1972 Cutlass Supreme Convertible (442 clone) -"Lady" (My mistress...)
http://www.flickr.com/photos/robsalbum/sets/
1986 Cutlass Supreme Coupe - "Pristine"
1978 Ford (Old Faithful) a.k.a. "the Tramp"
1997 Cadillac STS (for sale - too many cars!)
1999 Harley Davidson Sportster - "the Freedom Machine"
Lady72nRob71 is offline   Reply With Quote
Old July 19th, 2009, 12:27 PM   #4 (permalink)
svnt442
I agree. Using a fuse is a bad idea. THe rate at which a fuse blows is much different from a fusable link.
Another thought is what is the condition of the rest of the wiring? What caused the link to blow in the first place?
My 39 year old harness was (how should I put this) SHOT!! I had no clue just how bad until I pulled it off to install the new one.
__________________
Randy
1970 442
svnt442 is offline   Reply With Quote
Old July 19th, 2009, 12:45 PM   #5 (permalink)
Lady72nRob71
Good point above - what cuased the meltdown?
You could use the fuse and holder you have to help isolate and eliminate the short that caused the FL to blow. Fuses are easy to replace, After the short is opened, install the correct FL.
__________________
-Rob Young
Old July 19th, 2009, 03:26 PM   #6 (permalink)
gearhead1218
Good points made.
I don't know what caused the meltdown. I'm thinking something done by the PO. The heating circuit is now eliminated from the car, and it appears to be properly disconnected.
The only real HOKEY thing that I haven't checked is the Auto-meter Tach that is set into the dash next to the speedo. Maybe something shorted in the dash cluster when he mounted the tach.
I think I'll use the 30 amp set-up for now, then trace the rest of the circuits that is fed off that line for the fault.
__________________
John Castelli
2003 Chevy Siverado
2007 Chevy Impala
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Hello All - OAI new member here; My Car(s); post a link? AtzMaBoy Cars For Sale 4 April 28th, 2009 11:26 AM
Sway bar link stacking........ J-(Chicago) Chassis/Body/Frame 2 November 24th, 2007 10:05 AM
is this a good deal on a 455 ? (link inside) shaks 442 clone Big Blocks 7 November 20th, 2007 11:05 AM
can someone point me towards a link... 72Cutlass Drivetrain/Differentials 0 October 21st, 2007 02:42 PM
LINK to Carsurvey.org Interesting place. jaco Ninety-Eight 3 April 22nd, 2007 08:06 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
