| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
Got it running
Got my car running for the first time today. Its been sitting for 10 years. Put on HEI distributor, alternator and it fired right up. Smokes bad right now, maybe it will clear up.
One question. Where is the best place to get the 12 volts for the HEI distributor. I have it wired straight to the battery right now just to get it running. |
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
Hot Rodder at heart Administrator
Congrats! Some people use the horn relay to tap off from.
__________________
Dan '77 Cutlass Supreme '46 2 door "The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB. |
#3 (permalink) |
Landyacht Club President
The HEI distributor needs 12 volts ignition. You can either use the horn relay or you can disassembly the dash and run another wire from the 12 volts ignition that went to your coil originally. If you still have the 12 volts ignition resistor wire in the engine bay you can attach another wire to it and pull it through the fire wall.
__________________
Ferris, my father loves this car more than life itself... Apparently, you don't understand! Ferris, he never drives it! He just rubs it with a diaper! Cameron Frye Ferris Bueller's Day Off 1986 |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Running after 6yrs. | scrappie | General Discussion | 10 | April 3rd, 2009 10:58 AM |
| 69 H/O--What tires are you running? | Cameo White | Hurst/Olds | 9 | January 26th, 2009 08:23 AM |
| parting out a running 72 supreme | djsoldzparrts | Parts For Sale | 12 | August 31st, 2008 06:13 PM |
| running lean | projectheaven | Small Blocks | 1 | June 21st, 2008 11:21 AM |
| running 455 | mjscutlass | Parts Wanted | 1 | December 3rd, 2006 12:23 PM |
